john551 Posted December 2, 2009 Share Posted December 2, 2009 AutoCAD 2009 Civil 3D (new) user. Hi, I've been having trouble with making a drawing then creating a layout and having the scale I measure it by hand after plotting it out at 1:1 equal that of the viewport scale in the bottom right corner. To explain with an example: I start a new autocad drawing, then I draw a line and type in 600. I create a new layout and use the 11x17 classic template. Then I go into that layout and double click in model space to bring my 600 length line into extended view. The viewport scale at the bottom says 0.01999.. and so I take the rounded reciprocal of this and change it to 1:50. I right click on the layout and plot at 1:1 and hand measure my line with a 1:50 metric scale and it's around 15.24m. The only way it makes any sense is that 15.24m/2.54 to convert between metric and imperial is 600 inches. Format - Units says decimal. I want to be drawing in metric which I believe it is but having my viewport scale match that and can use that to make a scale bar for my plots. Or do I just have to accept that I need to divide the viewport scale by 2.54 everytime to make my scale bar? In which case the viewport scale would say 1:50 but my actual scale would be 1:19.7 (50/2.54) Help! thank you =) Quote Link to comment Share on other sites More sharing options...
iskalipsi Posted December 2, 2009 Share Posted December 2, 2009 what scale do you want in you layout? try this, after you double click on the layout,zoom and type 1/50xp then enter. then try to plot it in 1:1 and measure the line. Hope this helps Quote Link to comment Share on other sites More sharing options...
john551 Posted December 2, 2009 Author Share Posted December 2, 2009 That's the same thing as setting the scale to 1:50. The point isn't what scale I want per se it's that the scale in viewport seems to think my 600 m length line is really a 600x2.54 = 1524 length line. Sorry if any of my mm to cm to m 10ths are off, but the point is the problem is between metric and imperial. A 600 m line can fit on a landscape 11x17 piece of paper but at a scale of 1:2000. I mean just have a look a your 1 foot or 30 cm length scale if you have one and on 1:2000 scale the entire length can represent 600 m. But you put 1:2000 (or 1:200 or 1:20 whatever) into the viewport the line won't fit properly. It only lets it fit in the 1:50 scale range or what appears to be the a conversion between metric to imperial as 1 inch = 2.54 cm. And to reiterate I don't mean I can't change the scale to anything I want to, I can, it's just the viewportscale and what I draw are in metric and imperial rather than as one metric agreement (I believe). Quote Link to comment Share on other sites More sharing options...
john551 Posted December 2, 2009 Author Share Posted December 2, 2009 OK, I believe the problem is from this. If you select a 11x17 page in page setup manager the viewport scales are for that. If you select A3, the metric equivalent then the viewport scales change to match that. Although 2 Q's I have still arise. 1. Is it possible to select 11x17 or any other imperial sized paper and have the viewport scales 'adjust' to this as if it were a metric paper size. and 2. Should my viewport scale match exactly my scale ruler. By that I mean, the line of length 600 I drew fits nicely at a 1:2 scale but it's really a 1:2000 scale as the line is supposed to be 600 m. I realize autocad is probably set to draw in mm, but I don't want to type in 600000 and have my dimension show 600000. Either type in 600000 and dimension shows 600 m or type in 600 as drawing units in m and dimension be in m. Sorry if this is confusing, I'm confusing my own self trying to explain this better. Quote Link to comment Share on other sites More sharing options...
