Creating Layers with AutoLisp
sachindkini
Hi,
You can use entmake and specify properties in the dxf list (look at the developer's help > DXF Reference > TABLES Section > LAYER
Here's an example which creates a layer named "VPORTS", color 8, unplotable
(entmake
 (list
   '(0 . "LAYER")                                ; entity name
   '(100 . "AcDbSymbolTableRecord")              ; class
   '(100 . "AcDbLayerTableRecord")               ; sub class
   '(2 . "VPORT")                                ; name
   '(70 . 0)                                     ; flag (frozen, locked, etc)
   '(62 .                                      ; color
   '(6 . "Continuous")                           ; line type
   '(290 . 0)                                    ; plotable
   '(370 . -3)                                   ; line weight
Use TBLOBJNAME statement to see associated list of an existing layer as per example below:
(entget (tblobjname "LAYER" TheLayerToList))
Then create a similar list with desired features and add the new layer record to database using ENTMAKE.
Regards,
Creating Layers with all property (plot style, lw, discription, colour), dimension style & text style with AutoLisp
this will create layer with prperties and description
(defun _make_layer  (lname ltyp lwt col plot desc)
 (if (not (tblsearch "LAYER" lname))		  ;layer name
     (setq new_layer
     (vla-add
       (vla-get-layers
	 (vla-get-activedocument
	   (vlax-get-acad-object)))
       lname)
 (vla-put-description new_layer desc)		  ;description
 (vla-put-linetype
   new_layer
   (if	(tblsearch "LTYPE" ltyp)
     ltyp					  ;linetype
     "Continuous"))
 (vlax-put new_layer 'Lineweight lwt)		  ;lineweight
 (vla-put-plottable
   new_layer
   (if	plot
     :vlax-true
     :vlax-false))				  ;plottable
 (setq	accol (vla-getinterfaceobject
	(strcat	"AutoCAD.AcCmColor."
		(itoa (atoi (getvar "acadver")))))
 (vla-put-colorindex accol col)
 (vla-put-truecolor new_layer accol)		  ;color
 (vlax-release-object accol)
;;Usage:
(vl-load-com)
(defun C:DEMO  ()
 (_make_layer
   "NEW_LAYER"					  ;layer name
   "CENTER"					  ;linetype
   50						  ;lineweight
   162						  ;color
   T						  ;plottable
   "The layer description is goes here"		  ;description
  • 2 years later...
