problem with extrude
mahmoud abdallah
What seems to be the problem you're having with the ellipse? What is the variable PELLIPSE set to?
What are you trying to construct?
"...with making change of its major and minor diameters" Do you want to change the major and minor diameters as the ellipse follows the arc? Am I reading this correctly?
yea i succeed in that by drawing the two ellipse and the arc then making loft on the arc as a path
this component is an arm of a pulley
