Results 1 to 6 of 6
    Full Member
    AutoCAD 2009
    Mar 2009
    75
    Default reading xref file
    I often need to perform offset of objects existing in xref drawings. for that I have to first draw line/pline etc along the
    xref entity and then offset that new created line etc.
    Is it possible to directly offset the xref entity instead of first creating its copy in the working drawing.
    Thanks.
    Forum Deity NBC's Avatar
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    you could always NCOPY the entities from the xref (no need to redraw them then) then you could use offset ?
    Life's constantly changing - keep up or get left behind
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,710
    Alan,
    Quick question - what does the transformation matrix do in that code? - I've never really got to using one, (except in grvecs).
    Lee
    Lee Mac Programming
    Just another Swamper
    Luminous Being alanjt's Avatar
    Civil 3D 2011
    Apr 2008
    5,993
    Quote Originally Posted by Lee Mac View Post
    Alan,
    Lee
    Moves the cloned object to the correct location.
    DropBox | finding the light...
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
  5. #5
    Civil 3D 2011
    Apr 2008
    5,993
    Entmake a nested object and you'll see that it creates it at 0,0,0. You have to use the transformation matrix to correct the placement, based on the original object's matrix.
  6. #6
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,710
    Quote Originally Posted by alanjt View Post
    Gotcha - thanks dude
    Lee Mac Programming
  1. Need help in reading data file
    By T2L in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Jun 2009, 09:55 pm
  2. lisp reading a csv file??
    By BLOACH85 in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st May 2009, 03:39 am
  3. Reading a TXT file using LISP
    By CAD Panacea in forum AutoCAD RSS Feeds
    Last Post: 14th Jul 2008, 07:10 am
  4. Opening a file for reading in Lisp Ver 2007
    By muck in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Dec 2007, 09:25 am
  5. Reading a .FAS File
    By gman in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th May 2006, 01:22 pm
