Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 31
    Super Member AQucsaiJr's Avatar
    AQucsaiJr's Computer Details
    Windows XP Pro
    Dell Optiplex 330
    Dell
    Electrical
    AQucsaiJr's Discipline Details
    Engineering Technition / Power Utilities
    Electrical
    Power Utility Protection and Control Engineering
    Electrical 2012
    Nov 2008
    USA, Florida, Orlando
    511
    Default Too many layers!!! Need to merge them!
    So here is the deal,
    I have a list of bogus layers that exist in a bunch of drawings that need to be merged into the correct layer. I tried writing a script for this but not all the drawings have the bogus layers so the script gets stuck every time it reaches a layer that is not in the drawing. It is not a time saver to have to resume the script after every pause. Anyone know of a lisp or other type of program that can do this? I have attached the script I wrote up if maybe I can make some changes to it to have it work.
    Windows XP Pro
    Dell Optiplex 330
    Dell
    Electrical
    Electrical
    Electrical 2012
    Nov 2008
    511
    The script I wrote calls out the built in layer merge command. My problem is there are so many drawings that need this fix that I wanted to make this a batch file, however the script I wrote gets stuck to often and is not a time saver.
    Luminous Being alanjt's Avatar
    Civil 3D 2011
    Apr 2008
    5,998
    You could try something like this:
    Code:
    (defun MergeLayers (#OldLayers #NewLayers / #Layers)
      (setq #Layers (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))))
      (mapcar
        '(lambda (o n)
           (and (tblsearch "layer" o)
                (or (tblsearch "layer" n) (vla-add #Layers n))
                (vl-cmdf "_.-laymrg" "_n" o "" "_n" n "_y")
           ) ;_ and
         ) ;_ lambda
        #OldLayers
        #NewLayers
      ) ;_ mapcar
    ) ;_ defun
    Example:
    Code:
    (MergeLayers '("A" "B" "C" "D") '("1" "2" "3" "4"))
    DropBox | finding the light...
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,714
    A touch quicker:
    Code:
    (defun MergeLayers (#OldLayers #NewLayers)
      (setq #Layers (cond (#Layers) ((vla-get-layers
                                       (vla-get-activedocument (vlax-get-acad-object))))))
      (mapcar
        (function
          (lambda (o n)
                  (vl-cmdf "_.-laymrg" "_n" o "" "_n" n "_y")))) #OldLayers #NewLayers))
    Lee Mac Programming
    Just another Swamper
  5. #5
    Civil 3D 2011
    Apr 2008
    5,998
    Is there any benefit to (function over '( ?
    I thought about making the vla-get-layers global, but it seemed pointless since it would only be run once per drawing.
    Quote Originally Posted by Lee Mac View Post
    A touch quicker:
    Code:
      (mapcar
        (function
          (lambda (o n)
  6. #6
    Civil 3D 2011
    Apr 2008
    5,998
    Just because I was curious:
    Code:
    Command: (benchmark '( (tl) (ta) ))
    Elapsed milliseconds / relative speed for 32768 iteration(s):
        (TL).....1578 / 1.01 <fastest>
        (TA).....1593 / 1 <slowest>
        (TL).....1594 / 1 <fastest>
        (TA).....1594 / 1 <slowest>
        (TL).....1593 / 1 <fastest>
    Code:
    (defun tl ()
                                       (vla-get-activedocument (vlax-get-acad-object)))))))
    (defun ta ()
    (or #Layers (setq #Layers (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))))))
  7. #7
    Senior Member wizman's Avatar
    AutoCAD 2009
    Nov 2007
    Abu Dhabi / Philippines
    408
    try to benchmark it alan. i think vovka on theswamp is the one who pointed
    that it makes it faster.
  8. #8
    Civil 3D 2011
    Apr 2008
    5,998
    Quote Originally Posted by wizman View Post
    Code:
    Command: (benchmark '( (test1) (test2) ))
    Elapsed milliseconds / relative speed for 4096 iteration(s):
        (TEST1).....1625 / 1 <fastest>
        (TEST2).....1625 / 1 <slowest>
        (TEST1).....1609 / 1.02 <fastest>
        (TEST2).....1640 / 1 <slowest>
        (TEST1).....1609 / 1.01 <fastest>
    Code:
    (defun test1 (/)
      (repeat 10 (mapcar '(lambda (a b) (strcat a " " b))
              '("A" "B" "C")
              '("1" "2" "3"))))
    (defun test2 (/)
      (repeat 10 (mapcar (function (lambda (a b) (strcat a " " b)))
              '("A" "B" "C")
              '("1" "2" "3"))))
    I need to run it on something a little more complex.
  9. #9
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,714
    Alan,
    The global #Layers will be much quicker when running the function through a mapcar statement
    Your
    Code:
    (defun tl ()
    (defun ta ()
    Is not a valid comparison, as both have #Layers global.
    Lee Mac Programming
  10. #10
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,714
    Code:
    Elapsed milliseconds / relative speed for 65536 iteration(s):
        (TL).....1872 / 3.23 <fastest>
        (TA).....6053 / 1.00 <slowest>
    Code:
    (defun ta (/ #Layers)
      (setq #Layers (vla-get-Layers
                      (vla-get-ActiveDocument
    (defun tl ( )
      (setq #Layers (cond (#Layers) ((vla-get-Layers
    Lee Mac Programming
  1. VBA merge layers....copy content of a layer to other layer
    By faith_cad in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Dec 2009, 07:01 pm
  2. How do I merge a large number of layers?
    By Mackao in forum AutoCAD General
    Last Post: 26th Nov 2009, 01:41 pm
  3. Merge animation
    By christo in forum Rigging & Animation
    Last Post: 2nd Jun 2009, 02:23 pm
  4. Merge layers
    By fostertom in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Mar 2008, 10:48 pm
  5. How to merge?
    By aubob in forum AutoCAD Drawing Management & Output
    Last Post: 20th Jan 2005, 01:17 am
