Results 1 to 3 of 3
    Forum Newbie
    Architecture 2008
    Dec 2009
    1
    Default feet inches to metric
    I've drawn a set of house plans in architectural and need to convert them to metric because this house is being built in Brazil. My skill level is pretty low so I have no idea how to do this. I am using architecture 2009. Please help!
    Super Member
    Dipali's Computer Details
    windows 10
    TOSHIBA "SATELLITE"
    Intel inside CORE i7
    viewsonicVA1916w
    Architectural
    Dipali's Discipline Details
    ARCHITECTURE
    Architectural
    interiors
    AutoCAD 2015
    Dec 2007
    INDIA
    1,109
    open a blank drawing with metric template.
    go to tools>options>user preference> & under 'insertion scale', set 'source content unit' to 'inches' & 'target drawing unit' to 'milimeter'. Also make 'insunits' value '4'(mm) and
    than bring in this exisitng drawing there using insert comand.
    "An architect's most useful tools are an eraser at the drawing board & a wrecking bar at the site."
    Frank Lloyd Wright
    Super Member Tankman's Avatar
    Tankman's Computer Details
    XP Pro SP3
    IBM T60 Thinkpad™
    36" LCD Monitor/TV, 14" Thinkpad™ T60
    AutoCAD 2007
    Mar 2008
    Eastern PA, USA
    1,796
    Or, you could scale the entire drawing.
    How to convert a drawing from inches to centimeters (or vice versa)?
    First of all - an AutoCAD drawing in the modelspace is unitless. A drawing unit can be anything you wish. A square of 10x10 units can be 10mm, 10m, 10", 10 feet, whatever. The real physical units are required only when you want to represent the drawing model for the real world - for dimensioning, plotting (plot scale), paperspace and annotation functions.
    But if you really want to scale your drawing from inches to millimeters, centimeters, meters - or vice versa - e.g. from centimeters to inches, you can use the SCALE command.
    When going e.g. from inches to centimeters, you have to scale up your drawing 2.54x. Run the SCALE command, select All objects, specify 0,0 (global) as the reference point and enter 2.54 as the scale factor.
    You can prepare a menu macro button to perform this conversion operation automatically (menu macros use ";" instead of Enter) - some examples:
    [Inches->CM]^C^C_SCALE;_All;;*0,0;2.54;
    [Inches->MM]^C^C_SCALE;_All;;*0,0;25.4;
    [CM->Inches]^C^C_SCALE;_All;;*0,0;0.3937;
    Tankman
    "When the well is dry, we know the worth of water." Ben Franklin ~ 1746
  1. Feet to inches
    By keithshapiro in forum AutoCAD Beginners' Area
    Last Post: 22nd Mar 2009, 10:55 pm
  2. Convert Feet & Inches Drawing into Metric??
    By Unick in forum AutoCAD Drawing Management & Output
    Last Post: 1st Aug 2007, 03:39 pm
  3. Inches instead of feet
    By siderus in forum AutoCAD General
    Last Post: 16th May 2007, 08:46 pm
  4. Feet & Inches
    By ebjco in forum AutoCAD Drawing Management & Output
    Last Post: 6th Oct 2006, 02:36 pm
  5. inches to feet
    By giloosh in forum AutoCAD Beginners' Area
    Last Post: 13th Sep 2005, 10:49 pm
