SillyBilly Posted December 23, 2009 Share Posted December 23, 2009 Hello, all. I'm on AutoCAD 2007 and am having trouble refreshing xrefs. I'll be working on the xref file, save changes, and go back to the drawing that's referencing the xref, click refresh from the xref window, and the changes won't come through. It would also be nice to know if there is a typed command that would refresh xrefs as well. Thanks! Quote Link to comment Share on other sites More sharing options...
Cad64 Posted December 23, 2009 Share Posted December 23, 2009 Are you sure you're working on the correct xref? Could it be you've made changes to an xref with the same name in a different location? Double check the xref file path. Quote Link to comment Share on other sites More sharing options...
SillyBilly Posted December 23, 2009 Author Share Posted December 23, 2009 That'll do it. Ha! Thanks. Quote Link to comment Share on other sites More sharing options...
