Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    Junior Member
    AutoCAD 2010
    Dec 2009
    20
    Default How to separate united solids
    Hello, I am a a moderately advanced user. Is there a way to split solids, say, I have combined 6 boxes and a cylinder in the center to form a fan, via the union command, and now I want to separate them again. At present I have one solid entity. I can do stuff to faces and explode them, but don't know how to return to having six separate boxes and the cylinder. Slice is one option, thinking of one simpler
    Senior Member viviancarvalho's Avatar
    HVAC
    viviancarvalho's Discipline Details
    Engineer HVAC Project installation
    HVAC
    AutoCAD 2013
    Oct 2009
    Bahrain
    154
    Reid
    According to me slice is the only & the best option of seperating the solids. Although if you are finding it difficult,you can attach it here i ll try to do it for you.
    Super Member kencaz's Avatar
    kencaz's Computer Details
    XP Pro, Vista, Linux,W7
    HP,s Dell
    Mechanical
    kencaz's Discipline Details
    Designer/Machinist
    Mechanical
    AutoCAD 2013
    Jul 2007
    Las Vegas, NV
    759
    Quote Originally Posted by viviancarvalho View Post
    Reid
    I agree with the slice option, also you can set the solid history to Yes and it will show the outline of the separated solids for reference.
    KC
    Some of my AutoCAD and Inventor Pics and Videos...
    http://www.youtube.com/kencaz45
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    What is the system variable DELOBJ set to?
    DELOBJ
    "All defining geometry is retained."
  5. #5
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    If any of your slices are not planar then create Surface bodies for using with Slice. Use the option to retain both sides of the slice. You might check the tutorials in my signature.
  6. #6
    Junior Member
    AutoCAD 2010
    Dec 2009
    20
    Thank you. DELOBJ is 1. Slice will not work with spherical intersections. I am after a routine rather than a single task. Is DELOBJ equivalent to Record History? Cad keeps history of Boolean, but only as long as there is no editing to sub objects. I kept Record History turned on, but lost Boolean history anyway after editing some faces and could not retrieve it
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    DELOBJ
    "Controls whether geometry used to create 3D objects is retained or deleted."
    Since your variable was set to 1 the profile curves were deleted (includes those used with extrude, sweep, revolve and loft commands).
    You're asking if there is a routine (LISP?) for handling spherical intersections?
  8. #8
    Junior Member
    AutoCAD 2010
    Dec 2009
    20
    was not thinking about LISP in particular, just a principle in general. I'll see to DELOBJ, but ain't it the command line for Record History.
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Are you referring to SOLIDHIST?
    "Controls the default History property setting for new and existing objects. When set to 1, composite solids retain a “history” of the original objects contained in the composite."
  10. #10
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by Reid View Post
    Sure it will.
    I would not have record history turned on - I have seen many problems with this.
    If you follow the instructions in my tutorials Delobj should be off - put generating curves on hidden layers in case you need then later.
    Zip and attach your file here.
  1. How do I separate two solids?
    By Rob-GB in forum AutoCAD 3D Modelling & Rendering
    Last Post: 14th Apr 2009, 01:08 pm
  2. How to substract N number of solids from n number of solids using C# code
    By srikanthkamuju in forum AutoCAD Drawing Management & Output
    Last Post: 16th Oct 2008, 08:18 am
  3. Metric System Adoption in the United States?
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 16th Jul 2008, 02:10 am
  4. How do I Separate hatches?
    By Ikarikun in forum AutoCAD General
    Last Post: 4th Dec 2005, 07:37 am
  5. importing solids into 3dsmax5 - solids coming out see thru?
    By ironman2 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Sep 2005, 05:21 am
