muck Posted December 29, 2009 Share Posted December 29, 2009 Does AutoCAD 10 have a feature that will save or plot a pdf when a file is saved or plotted? If so, how do you use it? Thank you, Quote Link to comment Share on other sites More sharing options...
JD Mather Posted December 29, 2009 Share Posted December 29, 2009 when a file is saved or plotted? Not sure I understand the question. I don't think you would want a pdf created everytime you save a file (for me that would be about every 5 minutes). Are you simply asking how to create a pdf file? Or are you asking how to simultaneously create a plot and pdf file? Auto Save or Make a pdf with AutoCAD 10? Are you using v10 or v2010? v2010 has a built in driver. Quote Link to comment Share on other sites More sharing options...
Tankman Posted December 29, 2009 Share Posted December 29, 2009 Haven't used AutoCad '10 however, there are a number of free *.pdf printers available. CutePDF and Primo to name two. *.pdf writers install as a printer. Select your *.pdf writer and print away. You will have two files, one will be your drawing1.dwg the second would be drawing1.pdf. A simple procedure. http://www.primopdf.com/index.aspx http://www.cutepdf.com/products/cutepdf/Writer.asp Quote Link to comment Share on other sites More sharing options...
spikes2020 Posted December 29, 2009 Share Posted December 29, 2009 If you want to do auto save their are macro's you can write where one button will save and plot to a pdf, if you want. I wouldn't know too much about them but i am 100% sure it can be done as some guy wrote a button to do just that for me. I would look for macros or scripts, and i believe they are all done with command line scrips. I could ask the guy once he gets in... Quote Link to comment Share on other sites More sharing options...
muck Posted December 30, 2009 Author Share Posted December 30, 2009 Here is another thing I have been wordering about. AutoCAD has a AutoPublish command which makes a file but it is not a pdf. What is the purpose of that? Thank you, Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 30, 2009 Share Posted December 30, 2009 AUTOPUBLISH "Publishes drawings to DWF, DWFx, or PDF files automatically to a specified location." Quote Link to comment Share on other sites More sharing options...
muck Posted December 30, 2009 Author Share Posted December 30, 2009 So you can get the Autopublish command to publish pdf files?. All I could do is to get it to make Dwfx files. How do you use it for pdf files? I don't see where Autopublish prompts the user for pdf files? Thank you Quote Link to comment Share on other sites More sharing options...
JD Mather Posted December 30, 2009 Share Posted December 30, 2009 F1 search on autopublish, I let you do the reading. Quote Link to comment Share on other sites More sharing options...
mrbucket Posted December 30, 2009 Share Posted December 30, 2009 F1 search on autopublish, I let you do the reading. This needs to be more specific. Good Find, I no doubt will use this at some point. My issue is the amount of work that may be done in between saves. Saving frequently to have a build-up of files would not work for me then. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted December 30, 2009 Share Posted December 30, 2009 I had never used this before, so I did a bit of reading of the Help files myself. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted December 30, 2009 Share Posted December 30, 2009 Saving frequently to have a build-up of files would not work for me then. I don't know, looks to me like it will simply save two files rather than one keeping both the pdf and dwg up-to-date. Quote Link to comment Share on other sites More sharing options...
mrbucket Posted December 30, 2009 Share Posted December 30, 2009 I don't know, looks to me like it will simply save two files rather than one keeping both the pdf and dwg up-to-date. After looking at it again (the pic you posted), it looks like (of course I should just try this) that it will pdf all tabs and model space? Quote Link to comment Share on other sites More sharing options...
muck Posted January 4, 2010 Author Share Posted January 4, 2010 When I make a pfd with Autopublish I allways get Adobe program to come up. Is there a setting to keep Adobie form coming up when using autopublish? Thank you, Quote Link to comment Share on other sites More sharing options...
