Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    Senior Member
    AutoCAD 2009
    Oct 2009
    171
    Default another question...
    I know I have alot of questions, hopefully i will be able to contribute soon as well.
    I wrote the following lisp
    Code:
    (defun C:CN ()
      (setq CRosmod (getvar "osmode"))
      (setq CRcecho  (getvar "cmdecho"))
      (defun *error* (msg)                ;;;error handler
           (if CRcecho (setvar "cmdecho" CRcecho))    ;;;resets echo,osnap if you cancel/quit
           (if CRosmod (setvar "osmode" CRosmod))
           (princ msg)
           (princ))
        (setq CBP (getpoint "\nSpecify base point: "))
          (setq CL1 (getdist "\nSpecify width of channel: "))
          (setq CL2 (getdist "\nSpecify size of legs: "))
          (setq CW1 (getdist "\nSpecify thickness <0.125>: "))
          (if (= CW1 nil) (setq CW1 0.125))
             (setq P2 (list (+ (car CBP) CL1) (cadr CBP)))
             (setq P3 (list (car P2) (+ (cadr CBP) CL2)))
             (setq P4 (list (- (car P2) CW1) (cadr P3)))
             (setq P5 (list (car P4) (- (cadr P3) (- CL2 CW1))))
             (setq P6 (list (- (car P4) (- CL1 (* CW1 2))) (cadr P5)))
             (setq P7 (list (car P6) (+ (cadr P5) (- CL2 CW1))))
             (setq P8 (list (- (car P6) CW1) (cadr P7)))
          (setvar "osmode" 0)
           (setvar "cmdecho" 0)
          (command "_.pline" CBP P2 P3 P4 P5 P6 P7 P8 "close")
    This is a lisp to draw a U-Channel of any size and thickness. if you notice I highlighted a line in red. That line is used for the size of both legs of the channel. Sometimes one of the legs is longer than the other. So I'd like a 2nd line for the 2nd leg. However I would like that line to store the length of the first leg as a default size so you can just press enter if they are the same. So the line might read as follows
    "Specify size of first leg <maybe a previous size used>: "
    "Specify size of second leg <size of first leg>: " i can just press enter
    I can't put the variable in the <> because it will just print the variable name. I hope this makes sense, any help is greatly appreciated.
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,708
    Lee Mac Programming
    Just another Swamper
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,708
    This is how I would approach it:
    Code:
    (setq CL2 (getdist "\nSpecify Size of Leg 1: "))
    (setq CL3 (cond ((getdist (strcat "\nSpecify Size of Leg 2 <" (rtos CL2) "> : ")))
                    (CL2)))
    Also, I would advise you to either use IF statements or the initget function in your code, to allow for null user input
    Lee Mac Programming
    Super Member mdbdesign's Avatar
    mdbdesign's Computer Details
    XP PRO
    Homemade
    GIGABYTE G31M-ES2L
    INTEL CORE 2-QUAD-Q6600@2.4GHz
    4 GB
    NVIDIA GeForce 9800 gt 1gb
    WESTERN DIGITAL 500GB
    2 - 21" COMPACQ
    Mechanical
    mdbdesign's Discipline Details
    Designing Engineer in Engineering Department
    Mechanical
    Pressure tanks Oil processing & storage equip. Steel mill equip. Telecom towers & equip. Wind turbine towers Power plant structures etc.
    AutoCAD 2012
    Jan 2007
    Courtice, Ontario, Canada
    749
    And little info:
    Specify Size of Leg 1(@ base point):
    will be handy.
    Edit:
    What about channel rotation?
  5. #5
    Super Member David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    1,925
    Just to expand a little on what the others said and to clean up the code:
    Code:
    (defun C:CN (/ CRcecho CROsmod CRplwid CBP CL1 CL2 CW1
                   P2 P3 P4 P5 P6 P7 P8)
      (setq CRplwid (getvar "PLINEWID"))
      (setq *error*
         (lambda (msg)
           (princ msg)
           (princ)))
      (initget 1)
      (initget 7)
      (initget 7)
      (initget 6)
      (if (not CW1)
          (setq CW1 0.125))
      (setvar "osmode" 0)
      (setvar "PLINEWID" 0)
      (command "_.PLINE" CBP P2 P3 P4 P5 P6 P7 P8 "_Close")
      (setvar "PLINEWID" CRplwid)
      (prin1))
    -David
    R12 (Dos) - A2K
  6. #6
    Senior Member
    AutoCAD 2009
    Oct 2009
    171
    1) Thanks for all the great help. I"m looking into that post by lee mac, thanks
    2) I don't know what you mean by "Specify Size of Leg 1(@ base point):". And I was planing another line in the lisp to rotate the channel after it's drawn. I was thinking something along the lines of
    (command "_.rotate" "L" "" CBP pause)
    3) lol yeah that code does look alot cleaner and easier to read. I guess I need to learn to to keep my lisp's neat. And thanks for that PLINEWID line. I didn't think of that but I can see how that can mess up my channel. I personally rarely use plines with thickness but to make this a lisp for everyone it's a great thought.
  7. #7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,708
    I prefer to use "polar", so here is another way to approach things:
    Code:
    (defun C:CN (/ SysVars OldVals CBP CL1 CL2 CL3 CW1
      (setq SysVars '("CMDECHO" "OSMODE" "PLINEWID")
            OldVals  (mapcar 'getvar SysVars))
      (setq *error*
         (lambda (msg)
           (mapcar 'setvar SysVars OldVals)
           (princ msg)
           (princ)))
      (initget 1)
      (initget 7)
      (setq CL1 (getdist CBP "\nSpecify width of channel: "))
      (initget 7)
      (setq CL2 (getdist "\nSpecify size of Leg 1: " CBP))
      (initget 6)
      (setq CL3
        (cond ((getdist CBP (strcat "\nSpecify Size of Leg 2 <" (rtos CL2) "> : ")))
              (CL2)))
      (initget 6)
      (setq CW1 (cond ((getdist "\nSpecify thickness <0.125>: ")) (0.125)))
      (setq P2 (polar CBP          0 CL1)
            P3 (polar P2  (* 0.5 pi) CL3)
            p4 (polar P3         pi  CW1)
            p5 (polar p4  (* 1.5 pi) (- CL3 CW1))
            p6 (polar p5         pi  (- CL1 (* 2. CW1)))
            p7 (polar p6  (* 0.5 pi) (- CL2 CW1))
            p8 (polar p7         pi  CW1))
      (mapcar 'setvar SysVars '(0 0 0))
      (prin1))
    I have set the SysVars using a different method also.
    (Used some of your code David )
    Lee
    Lee Mac Programming
  8. #8
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,708
    Quote Originally Posted by guitarguy1685 View Post
    GetDist (and GetPoint) can accept a point argument, in addition to the string. (see VLIDE help files).
    Example in above code.
    I would use (entlast) to capture the polyline entity, or using entmakex:
    Code:
    (defun C:CN (/ CBP CL1 CL2 CL3 CW1 P2 P3 P4 P5 P6 P7 P8 POLY PTLST)
      (setq *error* (lambda (msg) (princ msg) (princ)))
      (initget 1)
      (initget 7)
      (initget 7)
      (initget 6)
      (setq CL3
              (CL2)))
      (initget 6)
      (setq ptLst
        (list CBP
          (setq P2 (polar CBP        0  CL1))
          (setq P3 (polar P2 (* 0.5 pi) CL3))
          (setq p4 (polar P3        pi  CW1))
          (setq p5 (polar p4 (* 1.5 pi) (- CL3 CW1)))
          (setq p6 (polar p5        pi (- CL1 (* 2. CW1))))
          (setq p7 (polar p6 (* 0.5 pi) (- CL2 CW1)))
          (setq p8 (polar p7        pi  CW1))))
      (setq poly (entmakex
                   (append (list (cons 0   "LWPOLYLINE")
                                 (cons 100 "AcDbEntity")
                                 (cons 100 "AcDbPolyline")
                                 (cons 90 8)
                                 (cons 70 1))
                           (mapcar (function (lambda (x) (cons 10 x))) ptLst))))
      (command "_.rotate" poly "" CBP pause)
      (prin1))
    Notice that you needn't change the Sys Vars such as OSMODE with entmakex, and you can add DXF group codes to change layer/width etc.
    For a quick format, you can click on the formatting button in the Visual LISP Editor
    Hope this all helps, and if you have any trouble understanding anything me or David has posted, don't hesitate to ask
    Lee
    Lee Mac Programming
  9. #9
    XP PRO
    Homemade
    GIGABYTE G31M-ES2L
    4 GB
    2 - 21" COMPACQ
    Mechanical
    Mechanical
    AutoCAD 2012
    Jan 2007
    749
    Smile
    Just where will be located leg #1?
    Lets keep in mind someone will use your code and it be easy to know if leg #1 is going to be close to base point or on opposed side.
  10. #10
    Senior Member
    AutoCAD 2009
    Oct 2009
    171
    thanx lee, a few questions
    1) I noticed you used cond instead of if? what is the advantage of cond over if? I thought cond was if there were more than 2 expressions
    2) I noticed you used (prin1) instead of (princ), what's the difference here?
    3) I'm not familiar with using Polar coords, what's the advantage over Cartesian coords?
  1. UCS Question
    By magic-chef in forum AutoCAD 3D Modelling & Rendering
    Last Post: 13th Aug 2008, 04:20 pm
  2. command line up arrow question, and grip edit distance question
    By Rebel in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Jun 2008, 03:15 pm
  3. Question
    By primoz in forum Feedback
    Last Post: 17th Apr 2006, 01:45 am
  4. a PDF question...
    By StykFacE in forum AutoCAD General
    Last Post: 12th Apr 2006, 04:20 pm
  5. Okay okay, another question
    Last Post: 11th Apr 2006, 03:43 pm
