Results 1 to 4 of 4
Thread: AxisCopy2
    Forum Newbie
    AutoCAD 2010
    Nov 2007
    8
    Default AxisCopy2
    you can use this macro to make multiple offset with different distances, you have to enter all distances and then select an entity and specify side to offset
    to install it, paste the 2 files in C partition, use load application command in AutoCAD to load the Lsp file and type "ax" to run it
    Any comments are appreciated
    Thank you
    Mostafa Abdo
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,023
    Has anyone here scoped out this macro?
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Enterprise 64 bit
    Dell Precision M4500
    Intel Core i5 2.40GHz
    8GB
    NVIDIA Quadro FX 880M
    280 GB
    2 x Samsung SyncMaster 2443 24''
    AutoCAD 2012
    Nov 2006
    Sthlm, Sweden
    4,595
    Quote Originally Posted by thesniper View Post
    Thank you
    Mostafa Abdo
    Mostafa, If you are looking for comments and feedback on this I would recommend that you post the code as just text here, wrap the code in code-tags ( [code] , [\code]) and it will look good anyway.
    It's all about making it easy for the customer to access your code.
    Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
    at the moment in one's personal UCS.
    Go to PLAN view instead. - Dadgad
    Forum Newbie
    AutoCAD 2010
    Nov 2007
    8
    the code for this command is very large about 200 lines, so it is hard to publish it I just want everyone to use it and report me does it work good or have any bugs.
    Thank you in advance
