Results 1 to 4 of 4
    Full Member
    AutoCAD 2008
    May 2009
    28
    Default Pieces of walls & windows print in color?
    when I plot with an "AIA LWT by Object" plot style everything plot black when I put it on the "standard" layer, except the inside hatch of the wall prints yellow & the glazing of the window prints blue and the glass prints yellow. I know its an embedded layer in the the components that make up the wall or window already created by Autodesk but is there a way to override those embedded layers so everything will print correctly on the standard layer?
    Thanks in advance for any suggestions!
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,588
    Quote Originally Posted by crosscad View Post
    Are you using plain AutoCAD or Architectural?
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Full Member
    AutoCAD 2008
    May 2009
    28
    AutoCAD Architecture 2008
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2017
    Nov 2007
    4,588
    You will need to post in an Architecture newsgroup as those settings are not in regular autocad. I don't have Arch in front of me so I can't tell you exact steps, but you will have to edit the file that holds all the definitions of the parts and pieces and change the plot style from normal to a named plot style. Or if using CTB then change to a black color. Wish I could give better help but no longer have arch on my machine.
  1. Windows plot in color
    By crosscad in forum AutoCAD Drawing Management & Output
    Last Post: 8th Dec 2009, 05:59 pm
  2. Color changes in PDF print
    By cpriedel in forum AutoCAD Drawing Management & Output
    Last Post: 5th Mar 2009, 08:53 pm
  3. Print color
    By Stephen Shafer in forum AutoCAD Drawing Management & Output
    Last Post: 27th Nov 2008, 08:38 am
  4. Walls full of windows
    By Galingula in forum Architecture & ADT
    Last Post: 8th Dec 2005, 09:11 pm
  5. Screen vs Print Color
    By BWW in forum AutoCAD Drawing Management & Output
    Last Post: 11th Oct 2005, 08:07 pm
