Results 1 to 5 of 5
    Junior Member DP-MWS's Avatar
    AutoCAD LT 2006
    Oct 2007
    14
    Default Associative dimensions
    I've been having trouble with re-associating dimensions in a 2D drawing. Both the drawing and dimensions are in model space. I have alternate units showing. I mention this because this issue seems to happen more when alternate dimensions are showing than when the alternate dimension is turned off. I've tried to re-insert the block associated with the dimension, but this does not solve the problem. The strange thing is that one end of the dimension will remain associated. I've attached the section of drawing that's giving me trouble.
    Any help would be appreciated. This is not the first time this has happened and the solution is eluding me.
    Thanks.
    Senior Member
    AutoCAD 2000
    Nov 2008
    182
    The answer to your question have something to do with "non-uniformly scaled block". See attachment.
    We learn more by looking for the answer to a question and not finding it than we do from learning the answer itself. ~Lloyd Alexander
    Senior Member
    AutoCAD 2000
    Nov 2008
    182
    Please take note of the command prompt.
    Senior Member
    AutoCAD 2000
    Nov 2008
    182
    I tried to explode your drawing, purge, and re-blocked and see the result.
  5. #5
    AutoCAD LT 2006
    Oct 2007
    14
    I didn't realize that I was doing something different when I created blocks.
    I will pay closer attention.
    Thank you for your help.
  1. Is it possible to create associative, PaperSpace dimensions using VBA
    By ginak in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Jul 2009, 09:32 pm
  2. Need ideas... rotating associative dimensions
    By frostrap in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Feb 2008, 01:02 am
  3. associative dimensions in x-refs
    By michaeloureiro in forum AutoCAD Drawing Management & Output
    Last Post: 10th Jan 2008, 04:06 pm
  4. Associative Hatching?
    By Rooster in forum AutoCAD Drawing Management & Output
    Last Post: 1st Jun 2007, 12:23 pm
  5. associative text??
    By GOLFBLDR in forum AutoCAD Beginners' Area
    Last Post: 12th Feb 2006, 07:05 pm
