BMore Posted January 7, 2010 Share Posted January 7, 2010 I know this is a completely ridiculous question, but I haven't used CAD in about a year and can't remember the answer and also had trouble finding an answer in the forum... For whatever reason, I can't get my viewport to show my model scaled correctly. Mspace is set up at 1:1, and the 11x17 pspace is also set up 1:1. I choose 1/4"=1' scale in my viewport, and end up with my model being tiiiiiiiiny in the middle of the page when it should just barely fit. I feel like maybe the problem is in my page setup, but I'm drawing blanks on how to fix it. Any help would be appreciated! Thank you! Quote Link to comment Share on other sites More sharing options...
rkent Posted January 7, 2010 Share Posted January 7, 2010 While the viewport is active try Zoom, 1/48XP. See if that makes a difference. Verify that your 11x17 is truly that size. Quote Link to comment Share on other sites More sharing options...
BMore Posted January 7, 2010 Author Share Posted January 7, 2010 Thanks for the reply, RKent, but unfortunately it didn't change anything. Scale stayed the same in the viewport. I double-checked the paper size and it's 11x17. Do you think it could be a problem with the initial file setup? Any advice on that? Thanks again! Quote Link to comment Share on other sites More sharing options...
rkent Posted January 7, 2010 Share Posted January 7, 2010 Rather than play the guessing game post your drawing or as much of it as necessary to show the problem. Quote Link to comment Share on other sites More sharing options...
BMore Posted January 7, 2010 Author Share Posted January 7, 2010 It's a simple site survey. This whole process began because I was curious to see if I could get the front yard on an 11x17 to take out in the field. 4201Hanover.dwg Quote Link to comment Share on other sites More sharing options...
mrbucket Posted January 7, 2010 Share Posted January 7, 2010 I opened it threw it on a tabloid size and scaled to 1/2"=1'-0". Which is obviously not what the drawing is supposed to be. Did you draw it yourself or acquire it? Is it supposed to be in decimal? Quote Link to comment Share on other sites More sharing options...
BMore Posted January 7, 2010 Author Share Posted January 7, 2010 I opened it threw it on a tabloid size and scaled to 1/2"=1'-0". Which is obviously not what the drawing is supposed to be.Did you draw it yourself or acquire it? Is it supposed to be in decimal? I did draw it myself. It's only in decimal because I couldn't remember how to change the units! Haha, I'm a sad case...places I've worked in the past have workspaces pre-setup. I'd prefer it to be in feet and inches. Will changing it out of decimal help with the problem? Quote Link to comment Share on other sites More sharing options...
mrbucket Posted January 7, 2010 Share Posted January 7, 2010 Yes, it will. Go to Format and then Drawing Setup. Try redrawing a portion of it and scaling it again. It should scale properly now. Quote Link to comment Share on other sites More sharing options...
ScribbleJ Posted January 7, 2010 Share Posted January 7, 2010 If you change it from decimal to architectural then you need to scale everything up 12 times. This will also allow you to choose an architect scale for your viewport. Otherwise add an engineering scale to your scale list (i.e. 1"=100') and use it. 1"=100' worked for me when I did it which is why I suggest it in my example. Quote Link to comment Share on other sites More sharing options...
BMore Posted January 7, 2010 Author Share Posted January 7, 2010 Thank you, MrBucket! That worked! One bit of dust knocked off my brain. I appreciate it Quote Link to comment Share on other sites More sharing options...
mrbucket Posted January 7, 2010 Share Posted January 7, 2010 Your welcome! ScribbleJ mentioned something very useful if you need to just convert it quick and not redraw it. Quote Link to comment Share on other sites More sharing options...
BMore Posted January 7, 2010 Author Share Posted January 7, 2010 Thanks to you, too, ScribbleJ! I ended up just drawing one line at the new scale and reference scaling the drawing so it's all correct now. Glad the solution was simple since I have 6 of these! So glad I came across this site...I'll definitely be scoring the archives for more knowledge. Quote Link to comment Share on other sites More sharing options...
mrbucket Posted January 7, 2010 Share Posted January 7, 2010 Thanks to you, too, ScribbleJ! I ended up just drawing one line at the new scale and reference scaling the drawing so it's all correct now. Glad the solution was simple since I have 6 of these! So glad I came across this site...I'll definitely be scoring the archives for more knowledge. Awesome site. Jump in and give advice and help troubleshoot if you can. I have learned so much from the peeps here. Dont be afraid to ask! Quote Link to comment Share on other sites More sharing options...
