AkaArh Posted January 12, 2010 Share Posted January 12, 2010 I have a raster plan and I have to colour differently the streets,the houses, the blocks each one on a different layer. I have set the layer on -Bylayer-example green colour on first layer. I have traced new lines overlapted on the original outlines with polylines enclosing the contour. I have tried to use the Hatch command but it doesn't works. But I cannot fill the new form created with my colour .One reason is because it tells me that it is not an object . How can I make the new countour object and how can I fill it ? Thank you very much! Quote Link to comment Share on other sites More sharing options...
CarlB Posted January 12, 2010 Share Posted January 12, 2010 If you have enclosed an area with a polyline, it should hatch. During the hatch command, you can select a closed object, or select a point inside an area enclosed by line, arcs, polylines, etc. If still having problems, copy & post the command prompts and error message you are getting. or post the drawing. Quote Link to comment Share on other sites More sharing options...
fuccaro Posted January 13, 2010 Share Posted January 13, 2010 AkaArh, is there a single polyline you selected for hatching? If you select a polyline, it must be a closed one. Or select the area by picking an inner point as CarlB wrote. I adjusted the thread title. Quote Link to comment Share on other sites More sharing options...
