CIRCLE TO POLY
A way to convert circle entities to polylines.
Code:
(vl-load-com)
(defun circ2poly
       (obj / ctr radio a b c d pts vla_poly color_use space)
  (if (wcmatch (getvar "acadver") "16*,17*,18*")
    (setq color_use (vla-get-colorindex (vla-get-truecolor obj))))
  (if (wcmatch (getvar "acadver") "15*")
    (setq color_use (vla-get-color obj)))
  (setq ctr (vlax-get obj 'center))
  (setq radio (vlax-get obj 'radius))
  (setq a (polar ctr pi radio))
  (setq b (polar ctr 0.0 radio))
  (setq c (polar ctr (* pi 0.5) radio))
  (setq d (polar ctr (* pi 1.5) radio))
  (setq pts (mapcar '2dpt (list a b)))
  (setq
    space (vla-objectidtoobject
     (vla-get-database obj)
     (vla-get-ownerid obj)))
  (if (not (vl-catch-all-error-p
      (setq vla_poly
      (vl-catch-all-apply
        'vla-addlightweightpolyline
        (list space
       (lstVariantarray (apply 'append pts)))))))
    (vla-put-closed vla_poly t))
  (vla-setbulge
    vla_poly
    0
    (getBulge a c b))
  (vla-setbulge
    vla_poly
    1
    (getBulge b d a))
  (putColor vla_poly color_use)
  vla_poly)
(defun 2dpt  (pt)
  (if (caddr pt)
    (list (car pt) (cadr pt))
    pt))
(defun putColor  (obj color_use)
    (setq vla_truecolor
    (vla-getinterfaceobject
      (vlax-get-acad-object)
      (cond
        ((wcmatch (getvar "acadver") "16*")
  "AutoCAD.AcCmColor.16")
        ((wcmatch (getvar "acadver") "17*")
  "AutoCAD.AcCmColor.17")
        ((wcmatch (getvar "acadver") "18*")
  "AutoCAD.AcCmColor.18")))))
      (vla-put-colorindex
 vla_truecolor
 color_use)
      (if obj
 (vla-put-truecolor obj vla_truecolor)))
      (vla-put-color obj color_use)))
  (vlax-release-object vla_truecolor)
  (setq vla_truecolor nil))
(defun lstVariantarray  (ptslist / arrayspace sarray)
  (setq arrayspace
  (vlax-make-safearray
    vlax-vbdouble
    (cons 0
   (- (length ptslist) 1))))
  (setq sarray (vlax-safearray-fill arrayspace ptslist))
  (vlax-make-variant sarray))
(defun getBulge  (fromvertex midp p2 / ang chord midc alt)
  (setq ang   (angle fromvertex p2)
 chord (distance fromvertex p2)
 midc  (polar fromvertex ang (* chord 0.5))
 alt   (distance midp midc))
  (cond
    ((zerop chord) 0.0)
    ((equal (angle midp midc)
     (rem (+ ang (* pi 0.5)) (* pi 2))
     1e-4)
     (/ alt chord 0.5))
    (t (/ alt chord -0.5))))
(defun ss2lst  (ss / i lst)
  (setq i (if ss
     (1- (sslength ss))
     -1))
  (while (>= i 0)
    (setq lst (cons
  (vlax-ename->vla-object
    (ssname ss i))
  lst)
   i   (1- i)))
  lst)
;; single
(defun C:SCIRC2POLY  (/ obj)
  (setq
    obj (vlax-ename->vla-object (car (entsel "\nSelect Circle: "))))
  (circ2poly obj))
;; multiple
(defun C:MCIRC2POLY  (/ ss lst)
  (if (setq ss (ssget '((0 . "CIRCLE"))))
      (setq lst (ss2lst ss))
      (foreach obj lst (circ2poly obj))))
  (princ))
