Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Junior Member
    AutoCAD 2008
    Mar 2009
    18
    Default Annotative, attribute dynamic block cannot be edited
    Not sure if this has been posted already.
    I have a block that is annotative, dynamic and has attribute properties. I copy it to another location but I cannot select it or edit it. I can see it. I regenerate the drawing and it still cannot be selected or edited. Any suggestions?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,024
    I think the variable ANNOTATIVEDWG specifies whether or not the inserted block will be seen as being annotative when placed into another drawing. I'm not 100% but give it a try and let us know what happens.
    Make the setting = 1.
    Junior Member
    AutoCAD 2008
    Mar 2009
    18
    The ANNOTATIVEDWG specifies whether or not the drawing will behave as an annotative block when inserted into another drawing. ie, if you create a block but forget to set it to annotative when you write it out, you can go into that file and set it to act as annotative.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,024
    Thanks.
    Is the block on layer Defpoints?
  5. #5
    Junior Member
    AutoCAD 2008
    Mar 2009
    18
    No, they are not.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,024
    Is the layer locked?
  7. #7
    Junior Member
    AutoCAD 2008
    Mar 2009
    18
    The block was selected normally and copied to a new location. It remains on the same layer as the original block.
  8. #8
    Forum Deity NBC's Avatar
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    Any chance you could upload the block ?
    Life's constantly changing - keep up or get left behind
  9. #9
    Full Member Krztoff's Avatar
    Krztoff's Computer Details
    Windows 7 64bit
    Some assembled no brand PC
    LX ASUS S1156 IP55 DDR3 SATA2 GBLAN
    Intel Core i7 870 2.93GHz
    8Gb 1333MHZ DDR3 NONECC
    QUADRO FX 380 PCIE 512M DL
    WD CAVIAR BLUE 500GB 3.5" SATA3
    Syncmaster710N and some Sony 17"
    Civil 3D 2011
    Feb 2009
    99
    In older versions of autocad (Like my #200 when messing around with annotative objects they turned "read-only" after the drawing was saved, then only the AUDIT command could bring them back to life. Don't know if they fixed that glitch in #2009, try running an AUDIT, maybe that helps.
  10. #10
    Junior Member
    AutoCAD 2008
    Mar 2009
    18
    NBC: this happens with many different blocks. No matter which block, if it is annotative and dynamic with an attribute, it becomes visible, but unselectable...until you save and close down autocad and reopen the drawing.
    Kiztoff: we've run audits on the drawings, blocks, etc.
    It seems localized to this one drawing. We may just have to rebuild it.
  1. Attribute rotation in dynamic block
    By JeepMaster in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jan 2013, 03:12 pm
  2. Dynamic Block 1:1 (DOOR) With Annotative Attribute tag
    By KiLLiNG-TiME in forum AutoCAD General
    Last Post: 24th Nov 2009, 01:48 pm
  3. Using a Field as an Attribute in a Dynamic Block
    By Dave-CSMW in forum AutoCAD General
    Last Post: 29th Sep 2008, 11:09 pm
  4. Dynamic Block - Attribute Extraction
    By JBullseye74 in forum AutoCAD Drawing Management & Output
    Last Post: 10th Sep 2008, 04:30 pm
  5. Dynamic Block, Attribute, Visibility
    By Megumby in forum AutoCAD General
    Last Post: 2nd Aug 2007, 09:08 am
