Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 43
Thread: drawing a bolt
    Full Member
    AutoCAD 2007
    Jan 2010
    56
    Default drawing a bolt
    im having trouble drawind a 3d solid bolt.....
    its 5/16 thick 3/4in long and .5 in head and a nut on it....
    and i also have a bearing on that bolt..
    the bearing is 1/4 thick outside is 7/8 and inside is 5/16
    can anyone help?
    Full Member
    AutoCAD 2007
    Jan 2010
    56
    plzzzzz
    Senior Member iskalipsi's Avatar
    Architectural
    iskalipsi's Discipline Details
    designer
    Architectural
    Office planning. Furniture design. Minor estimate of civil works.
    AutoCAD 2009
    Sep 2009
    Philippines
    237
    Don't work too hard. Nobody notices anyway.
    Super Member SuperCAD's Avatar
    SuperCAD's Computer Details
    Win7 Professional 64bit
    HP Z420
    32G
    NVIDIA Quadro 4000
    150GB SSD
    1TB HDD
    LG W2353VP & LG W2343T
    Manufacture
    SuperCAD's Discipline Details
    CAD Manager
    Manufacture
    Design custom cabinetry and fixtures for retail and food service businesses.
    AutoCAD 2014
    Sep 2008
    WI, USA
    618
    Or better yet:
    http://www.cadtutor.net/forum/showth...t=screw+thread
    There is a flaw with Ellen's video. The threads are not perpendicular to the root body. She missed the step where you have to align the thread profile with the helix.
    What are you drawing that requires a threaded bolt? Speaking from experience, it's almost a waste of time to go to this level of detail. If you're like me and just want to see if you can do it, then have at it. If not, then I wouldn't as there are simpler ways to show a threaded part.
    Chuck Norris counted to infinity...
    Twice.
  5. #5
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    Quote Originally Posted by SuperCAD View Post
    Or better yet:
    I haven't looked at the video yet, but if you are referring to using the align option of Sweep, that would be incorrect.
    If you chase a thread on a lathe with a single point tool the top face of the 60° toll remains parallel to the floor, that it, it does not continuously align perpendicular to the helix spline.
    http://home.pct.edu/~jmather/content...torial%204.pdf
    PS: OK I loooked through the video and the threadform does not look like any thread I have seen before. Didn't take the time to check where it went wrong.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  6. #6
    Super Member Tankman's Avatar
    Tankman's Computer Details
    XP Pro SP3
    IBM T60 Thinkpad™
    36" LCD Monitor/TV, 14" Thinkpad™ T60
    AutoCAD 2007
    Mar 2008
    Eastern PA, USA
    1,794
    Quote Originally Posted by Elektryk View Post
    plzzzzz
    3D, wow! Why not ask the manufacturer for some 3D *.dwg files?
    Tankman
    "When the well is dry, we know the worth of water." Ben Franklin ~ 1746
  7. #7
    HP Z420
    32G
    NVIDIA Quadro 4000
    150GB SSD
    1TB HDD
    Manufacture
    CAD Manager
    Manufacture
    AutoCAD 2014
    Sep 2008
    WI, USA
    618
    Quote Originally Posted by JD Mather View Post
    I've done the same thread and I know that something is missing from her method. It's either align or base point, because my threads have turned out wrong when I didn't use those options. She wasn't making a particular threadform in that video. I've seen the step by step method and she got it right on that one. She just screwed up (no pun intended) in the video.
    Twice.
  8. #8
    Full Member
    AutoCAD 2007
    Jan 2010
    56
    Or better yet:
    actually no it does't have to be threaded... all i need is to show just the tip of the bolt and then the nut and the bearing on it... maybe i could get away without the thread but then again im having trouble drawing the nut the head and the bearing... the bearing i dont even know where to start ;(
  9. #9
    Super Member kencaz's Avatar
    kencaz's Computer Details
    XP Pro, Vista, Linux,W7
    HP,s Dell
    Mechanical
    kencaz's Discipline Details
    Designer/Machinist
    Mechanical
    AutoCAD 2013
    Jul 2007
    Las Vegas, NV
    755
    I agree the vid is flawed... The profile is swept incorrectly and also you always remove material never add. Cut threads are just that... Cut.
    KC
    Some of my AutoCAD and Inventor Pics and Videos...
    http://www.youtube.com/kencaz45
  10. #10
    HP,s Dell
    Mechanical
    Designer/Machinist
    Mechanical
    AutoCAD 2013
    Jul 2007
    Las Vegas, NV
    755
    You don't have to use helical threads just to show them. You can use a straight revolved profile and it looks pretty much the same. You can do it in 2D or 3D.
    For the bearing I would revolve the profile or cross section around an axis, (X in the picture), at the desired radius. You can do this for the inside and outside profiles. Then just polar array some spheres and you have a bearing.
    KC
  1. 3d Bolt
    By Neil in forum AutoCAD 3D Modelling & Rendering
    Last Post: 16th Apr 2009, 10:59 am
  2. 3D Bolt Threads
    By jar3232 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Apr 2009, 11:52 am
  3. Cant seem to render my nut and bolt
    By spursnutter in forum AutoCAD 3D Modelling & Rendering
    Last Post: 1st Jul 2008, 01:02 pm
  4. Bolt Thread
    By paulo in forum AutoCAD General
    Last Post: 6th Apr 2006, 11:53 am
