Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 43
Thread: drawing a bolt
  1. #11
    Full Member
    AutoCAD 2007
    Jan 2010
    56
    hmmm ;( ok....
  2. #12
    Super Member SuperCAD's Avatar
    SuperCAD's Computer Details
    Win7 Professional 64bit
    HP Z420
    32G
    NVIDIA Quadro 4000
    150GB SSD
    1TB HDD
    LG W2353VP & LG W2343T
    Manufacture
    SuperCAD's Discipline Details
    CAD Manager
    Manufacture
    Design custom cabinetry and fixtures for retail and food service businesses.
    AutoCAD 2014
    Sep 2008
    WI, USA
    622
    www.mcmaster.com
    There are a lot of bolts that you can find CAD files for there. The threads are anything but perfect though, but good enough for just showing a picture. There are a lot of bolts in 3D as well. I snag CAD files from this site all the time and they are a preferred vendor where I work.
    Chuck Norris counted to infinity...
    Twice.
  3. #13
    Full Member
    AutoCAD 2007
    Jan 2010
    56
    Quote Originally Posted by SuperCAD View Post
    how do you get the cad files?
  4. #14
    Full Member
    AutoCAD 2007
    Jan 2010
    56
    ok i got it... but i cant get them in cad 3d solids... only in 2d...
    there is something like 3dsolidworks something but i cant open it
  5. #15
    HP Z420
    32G
    NVIDIA Quadro 4000
    150GB SSD
    1TB HDD
    Manufacture
    CAD Manager
    Manufacture
    AutoCAD 2014
    Sep 2008
    WI, USA
    622
    Download the 3-D SAT file (not all of them have this option though) and then "import" it into AutoCAD. You have to click on File and then Import in AutoCAD, select the SAT file and click OK.
    Just a warning, you may have to scale the object for it to work. For instance, if you're working in imperial measurements some of the bolts will look enormous. You'll have to scale them by a 0.03937 scale factor.
    Twice.
  6. #16
    Full Member
    AutoCAD 2007
    Jan 2010
    56
    ohh ok lemme see
  7. #17
    Inventor 2013
    Sep 2007
    Williamsport, PA
    7,006
    If you are a student you can download Autodesk Inventor for free from http://www.autodesk.com/edcommunity Inventor has 3D libraries of standard stuff like nuts, bolts, washers, cotter pins, bearings, fittings.... built in.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  8. #18
    Full Member
    AutoCAD 2007
    Jan 2010
    56
    i did imported and nothing happened
  9. #19
    Full Member
    AutoCAD 2007
    Jan 2010
    56
    Quote Originally Posted by JD Mather View Post
    no im not a student.... but it would help
  10. #20
    Inventor 2013
    Sep 2007
    Williamsport, PA
    7,006
    Quote Originally Posted by Elektryk View Post
    ACISIN command.
    You might first open the file in Notepad and make sure it is ACIS v7 or earlier. Autodesk products will only read up to ACIS v7 (*.sat files).
    In any case, it should only take 5-10 minutes to create these parts and good practice on easy stuff. What are you having difficulty with (zip and attach dwg attempt).
  1. 3d Bolt
    By Neil in forum AutoCAD 3D Modelling & Rendering
    Last Post: 16th Apr 2009, 10:59 am
  2. 3D Bolt Threads
    By jar3232 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Apr 2009, 11:52 am
  3. Cant seem to render my nut and bolt
    By spursnutter in forum AutoCAD 3D Modelling & Rendering
    Last Post: 1st Jul 2008, 01:02 pm
  4. Bolt Thread
    By paulo in forum AutoCAD General
    Last Post: 6th Apr 2006, 11:53 am
