Results 1 to 2 of 2
    Full Member
    AutoCAD 2010
    Oct 2009
    44
    Default AutoCAD Timesavers - what does it do?
    AutoCAD Timesavers
    1. In OptionsOpen and Save tab, set the "Incremental Save Percentage" to 100. This is the variable ISAVEPERCENT.
    2. In OptionsOpen and Save tab, when saving down to a previous version, clear the checkbox for "Maintain Visual Fidelity for Annotative Objects".
    3. In OptionsSystem tabLayout Regen Options, set it to "Cache Model Tab and Last Layout". This is equivalent to setting the LAYOUTREGENCTL to <1>.
    4. Viewres is a very close relative of Blipmode. Thankfully, Blipmode/On is no longer the default, but not many of us got the memo about Whiparc superseding Viewres. Set WHIPARC to <1> and you won't get hexagons for circles anymore when you zoom in.
    5. In the Workspace Settings dialog box, your system will move quicker if you set it to "Do Not Save Changes To Workspace".
    http://www.cadtutor.net/corner/2010/january.php
    So, what does this things do? Is it rekommended to do?
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,375
    Set this to 0, this was a lame attempt back in R13 (I think) to speed up saves. See Help.
    Use Visual Fidelity if you are having to save down to previous versions, if not then don't use it. See Help.
    I always set to Regen when switching. But you should experiment and find what works for you.
    Viewres is not related to blipmode in any way that I can think of. Set Viewres to the lowest setting you can live with, I get by just fine with 500. Whiparc will cause more problems than it solves, imho. See Help.
    If you are sure you will remember to save when you puposely change something then this is not a problem.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  1. Replies: 0
    Last Post: 28th Jul 2008, 07:30 pm
  2. Google Earth Extension for AutoCAD 2007, AutoCAD 2008, and AutoCAD 2009
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 22nd Apr 2008, 11:00 pm
