Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    Forum Newbie
    AutoCAD 2007
    Jan 2010
    7
    Default Problem with connect 2 circles
    I have the attached image to do in autocad:
    but i can't figure a way how to connect the circles in order to make the out line. When i use fillet, the line goes from the wrong side. Note that the two little circles have (both of them) radius 14.
    Thanks in advance.....
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,023
    What do you mean by "connect the circles"? The two "little" circles are not connected to anything.
    Lines may be "joined" to create polylines. Arcs can be joined to lines as well.
    Senior Member
    AutoCAD 2000
    Nov 2008
    182
    "have (both of them) radius 14. "
    You mean 140?
    Draw The 2-40R's as circles first and use Cirle Tan Tan command to draw the 140R.
    Afterwards you can do a trim.
    Forum Newbie
    AutoCAD 2007
    Jan 2010
    7
    i mean connecting the circles with rad 40 and 28 rad (the one up and the one down) with the arc of 140R
  5. #5
    Forum Newbie
    AutoCAD 2007
    Jan 2010
    7
    the arc does not has a known center
  6. #6
    Super Member nukecad's Avatar
    nukecad's Computer Details
    XP64
    Various machines.
    AutoCAD LT 2006
    Apr 2009
    NW Cumbria (English Lake District)
    500
    From the centre of the rad 40 draw a circle of rad 180 (40+140) from the centre of the rad 28 draw a circle of rad 168 (28+140) where these two circles intersect is the centre of the rad 140.
    *** Out of Beer Error ->-> Recovering Memory***
  7. #7
    Forum Newbie
    AutoCAD 2007
    Jan 2010
    7
    Quote Originally Posted by nukecad View Post
    Using this method, the arc is designed by the wrong side.
    edit:
    Mathematically i think that the problem can not be solved...
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,023
    Mathmetically the problem has one flaw. The radius of 185 is incorrect. Other than that the problem can be solved using AutoCAD. Note that the circle command with the TTR option does work as that is what I used to draw the image shown below.
  9. #9
    Forum Newbie
    AutoCAD 2007
    Jan 2010
    7
    How did you do this? I draw all the circles expect of the 185 and 110 which i can't draw...
  10. #10
    Super Member mdbdesign's Avatar
    mdbdesign's Computer Details
    XP PRO
    Homemade
    GIGABYTE G31M-ES2L
    INTEL CORE 2-QUAD-Q6600@2.4GHz
    4 GB
    NVIDIA GeForce 9800 gt 1gb
    WESTERN DIGITAL 500GB
    2 - 21" COMPACQ
    Mechanical
    mdbdesign's Discipline Details
    Designing Engineer in Engineering Department
    Mechanical
    Pressure tanks Oil processing & storage equip. Steel mill equip. Telecom towers & equip. Wind turbine towers Power plant structures etc.
    AutoCAD 2012
    Jan 2007
    Courtice, Ontario, Canada
    749
    Read ReMark post again.
    Mine is below:
  1. How to connect 2 Pipe in 3D?
    By tchong23 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 10th Oct 2009, 07:59 pm
  2. How Do I Connect 2 Surfaces?
    By backpack09 in forum AutoCAD General
    Last Post: 23rd Oct 2007, 07:23 pm
  3. Connect the dots
    By Tiger in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Sep 2007, 09:36 pm
  4. db connect
    By wastewater in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Feb 2007, 01:40 am
  5. Problem snapping arcs to tangent of circles
    By G. De Angelis in forum AutoCAD Beginners' Area
    Last Post: 26th Oct 2006, 11:23 am
