Autocad 2009 - menus, ribbons and command line
zionshea
Hi all,
Please see attached file and help in the following:
1. How do I bring back the menu items?
2. How do I bring bcack the ribbon tabs or pannels?
3. How do I put the command line to its old place, to the lower part ofthe screen?
Thanks.
3. Try pressing Ctrl+9 or go to Tools > Command line.
Update: Confirmed. Ctrl+9 will hide and unhide the command line. I tried it using 2007.
Does '07 use the same command line input as '09? His post says, "2009."
Poster refers to '09 but his profile says, '08? :?
Confirmed. Ctrl+9 will hide and unhide the command line.[/i]
But it at it and so unhide, only not in that place. It is necessary to only take it and to drag downwards. If does not last it is necessary LOCKUI-> 0 to unfasten windows wink.gif
Thanks all for your prompt answer.
1. Menubar=1, this helped - thanks.
2. CUIload, not sure what should do with this popup menu to remove the the message "The ribbon does not have any tabs or pannels currently loaded" and bring back the tabs and pannels.
3. Command line: The and the worked fine - thanks.
The CUI with ACA 09 will occasionally get corrupted. There is a place where you can copy the backup back into the right folder to get it working again. Doing reinstall sometimes works, sometimes not. I have had the problem several times, and it is a pain in the rear every single one of them.
I managed to fix this "The ribbon does not have any tabs or pannels currently loaded" with the Repair option.
When I type CUIload I get the attached screen.
