turning a line into a solid
rookie37
The gif is 2 sundials
The green one wit purple numbers and a blue stick in the center is an armillary dial. the blue stick casts a shadow on the purple number
The one below it is an analemmatic dial. You paint it on the ground. In the summer, stand on the mark "Summer" and your shadow will point to the hour number in blue
I need to project lines from the armillary dial to draw the other one.
At the moment I'm extruding 1mm diam circles to make cyliners
If I extude lines. can I make them wider (1mm) to make them stand out?
These projections are at unknown angles. I need to project first before I can find the angle and even then I don't know (have never tried) to read it
It's easy to draw a circle in a standard plane. I have never tried to extude a circle to follow the path of a different plane. Can I?
These projections are at unknown angles....
Doesn't matter where the circle is - it can be anywhere.
Use Sweep instead of Extrude. Sweep command will automatically line your circle up on path.
