Results 1 to 4 of 4
Thread: Block issue
    Full Member
    Scoobydoo's Computer Details
    Windows 7 Pro
    Dell Precision T5500
    Intel XEON E5620 2.40 GHz
    6 GB
    NVIDIA Quadro FX 3800
    250GB
    Dell 24" LCD
    Utilities
    Scoobydoo's Discipline Details
    Electrical Utility
    Utilities
    AutoCAD 2013
    Jun 2008
    Southeast Arizona
    64
    Default Block issue
    I have a 6-sided polygon block (we use them for station numbers) that contains annotative text (plots 1/8” on paperspace). When I insert the block in onto the model (the model is setup with an annotation scale of 1:10), the text scales correctly, but the polygon does not. How do I fix this?
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,798
    A block does not auto scale as a rule but if your using Civil 3d yes it will autoscale blocks.
    The other way is maybe use "filter" blocks and just change x,y scale. If your using annotative text its not going to work.
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,798
    Just another thought rather than a block why not a font charcter use a TTF have a look at windings for a start, The character could be annotative and it would change size automaticly. Check Lee macs recent work regarding placing text at a survey point.
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,401
    Quote Originally Posted by Scoobydoo View Post
    You need to set annnotative for the block. Start the block command, pick the block name, pick annotative, pick ok, yes to redefine.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  1. Block issue
    By MisterJingles in forum AutoCAD Beginners' Area
    Last Post: 28th Apr 2009, 11:16 am
  2. Title Block Issue
    By mingom in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Dec 2008, 11:55 am
  3. Block Issue
    By johnengineer in forum AutoCAD Beginners' Area
    Last Post: 23rd Sep 2008, 06:24 pm
  4. Block insertion issue
    By Hardney in forum AutoCAD Drawing Management & Output
    Last Post: 19th Mar 2008, 04:53 pm
  5. Title Block Issue
    By Stephanie in forum AutoCAD Beginners' Area
    Last Post: 17th Jul 2007, 07:45 pm
