Align In Autocad 2009
mcad88
Hi
I am using Autocad 2009 with xp pro 32bit. Using ALIGN command in a drawing, when I type in the command and pick the two points of the object to align, the object either scales down or scales up depending on the object I want to align with.
I will be grateful for your help, this is my first time on the forums for help.
Thanks in advance.
Mcad88
This is the command line history when I use Align, using two points
Command: ALIGN
Select objects: 1 found
Select objects:
Specify first source point: ENDP,INT
of
Specify first destination point: ENDP,INT
of
Specify second source point: ENDP,INT
of
Specify second destination point: ENDP,INT
of
Specify third source point or :
Scale objects based on alignment points? [Yes/No] :
If you use three points, you don't get an option for scaling
lpseifert
Thanks for you quick response, must say all the response I had has been great.
I used align then used only one align command, this helped.
Thanks again
Mcad88
