MisterJingles Posted January 21, 2010 Share Posted January 21, 2010 Hi guys When I set the draw order of certain object to back or front, most of the time it changes itself back next time I check. Why would it do this and is there any way I can ensure the order stays as I have set it as I find myself doing it over and over again? Thanks Rob Quote Link to comment Share on other sites More sharing options...
Connect Project Tech Posted January 21, 2010 Share Posted January 21, 2010 Maybe it has something to do with the 'Z' value or elevation of the objects? Also.... In options under drafting there a box at bottom left : Replace Z Value With Current Elevation When un-ticked everything seems to be set at the same Z value Its caused me a few problems in the past when filleting & things - might be worth a look. Quote Link to comment Share on other sites More sharing options...
stevsmith Posted January 21, 2010 Share Posted January 21, 2010 I have a lisp set to put all my dimensions to the back. Basically all my dimensions are set on a "dim" layer and the code move the "dim" layer to the back. Move to back (Dims).LSP Quote Link to comment Share on other sites More sharing options...
MisterJingles Posted January 21, 2010 Author Share Posted January 21, 2010 Stevie - I use LT mate, thanks for rubbing it in C P T - The Z value if the object I need to remain at the back is set to 0 already. This I found in Properties, the check box in the bottom left corner of the Drafting tab does not show in mine (LT again?) Regards Quote Link to comment Share on other sites More sharing options...
stevsmith Posted January 21, 2010 Share Posted January 21, 2010 Sorry mate, I did not realise, even though it says so in you profile. Quote Link to comment Share on other sites More sharing options...
nukecad Posted January 21, 2010 Share Posted January 21, 2010 Not sure if this applies with LT2010 but is it getting re-sorted by a regen or redraw? SORTENTS variable and/or the OPTIONS > USER PREFERENCES dialogue control the object sorting. Quote Link to comment Share on other sites More sharing options...
MisterJingles Posted January 25, 2010 Author Share Posted January 25, 2010 NUKECAD - I regen this drawing often, perhaps this is messing up the draw order as you say. I will try your suggestion and report back. Thanks Quote Link to comment Share on other sites More sharing options...
CarlB Posted January 25, 2010 Share Posted January 25, 2010 Draworder has not been reliable for hatches & blocks. But what works to bring objects to the front is to copy objects over themselves (0 displacement), then delete "previous" (the original objects). Quote Link to comment Share on other sites More sharing options...
MisterJingles Posted January 27, 2010 Author Share Posted January 27, 2010 The objects Im having problems with are blocks or are hatched so it makes sense then. Thanks for the tip Quote Link to comment Share on other sites More sharing options...
