Hi Woodman,
Im not too sure about the approach you are mantioning, but I do something similar using MX, basically I just create a new model with just the strings that represend the boundary (usually the highway boundary in my case.) Then I construct a vertical wall over every string. This extra model is cut along with the rest of the sections as you have done in your example, but it gives two vertical lines in the section. (We use this purely as an indication of clearence to the Highway boundary), but a similar method could be used to save you a bit of time, unless anyone can think of a better solution?
Brin
