mguenthner Posted January 21, 2010 Share Posted January 21, 2010 I've inserted a JPEG image of a map that I exported from GIS into model space. The image shows up fine when I print preview in paper space, but the image does not print. Any suggestions? Quote Link to comment Share on other sites More sharing options...
mguenthner Posted January 21, 2010 Author Share Posted January 21, 2010 I'm using AutoCAD LT 08. Quote Link to comment Share on other sites More sharing options...
todouble22 Posted January 21, 2010 Share Posted January 21, 2010 I'm using AutoCAD LT 08. CHECK to see what layer the image is on? make sure it is on a layer that plots . also check image frame on or off. I'd guess its not on an appropriate layer.. Quote Link to comment Share on other sites More sharing options...
mguenthner Posted January 21, 2010 Author Share Posted January 21, 2010 Still didn't work. The image is on a layer that prints and the imageframe is set to 1. Quote Link to comment Share on other sites More sharing options...
Shtevil Posted January 22, 2010 Share Posted January 22, 2010 If the image is an OLE it can sometimes cause printer memory issues, We have that problem sometimes so we get all our users to insert images using the attach image option in the x-ref command. give that a try Quote Link to comment Share on other sites More sharing options...
nukecad Posted January 22, 2010 Share Posted January 22, 2010 Is your printer driver a postscript driver? (usually named with PS2 or PS3). We have had problems ploting images and pdfs when using a PS3 driver. Luckily we also had a PCL6 driver for the plotter, setting this as the default driver cured the problem. Quote Link to comment Share on other sites More sharing options...
