I don't use the Mirror modifier, I like the Symmetry modifier better.
There are little buttons underneath the modifier stack window. One of them says "Show End Result On/Off Toggle". Use that and you will be able to see both halves of your model while working.
You need to move the objects pivot point to the snap point where you want the mirroring to occur. You can do that by using the controls in the "Hierarchy" rollout menu's.
