Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
  1. #11
    Forum Deity shift1313's Avatar
    not applicable
    Sep 2008
    VA
    2,859
    to answer your question. Have you used the trim to frame button? Its on the design tab.
    Where are you located? A friend of mine has a car you might like, a 240sx with an infinity v8 with a huge turbo. He does mostly drag racing. Since i see you have a solid axle sitting on the table im going to assume the same for you, or you are planning on a lot of power
    Matt - Certified Solidworks Expert -Advanced Surfacing, Mold Tool and Sheet Metal Specialist
    Current Software: SolidWorks11,SolidCam11
    http://www.solidworkslessons.info/
    www.mysolidbox.com
  2. #12
    Inventor 2013
    Sep 2007
    Williamsport, PA
    7,005
    At some point in your training they should have covered the fact that an assembly with out parts (just like the real world) is useless. The iam file is simply a list of hyperlinks to part files and a record of constraints and a bit more. Need the ipt files.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  3. #13
    Inventor 2013
    Sep 2007
    Williamsport, PA
    7,005
    Quote Originally Posted by shift1313 View Post
    Doesn't work on bent frame members.
  4. #14
    not applicable
    Sep 2008
    VA
    2,859
    Quote Originally Posted by JD Mather View Post
    Does trim/extend work on bent members? just like using the bend as the terminator.
    www.mysolidbox.com
  5. #15
    Inventor 2013
    Sep 2007
    Williamsport, PA
    7,005
    Here is step-by-step.
  6. #16
    Junior Member
    Inventor 2011
    Jan 2010
    22
    So, each frame generator tube in assambly should be copy in to new part file after creating?
    All main frame can be created in one part file? Or each part should be created separatelly?
    Pamata_ramis_1.zip
  7. #17
    Inventor 2013
    Sep 2007
    Williamsport, PA
    7,005
    Only need to copy trimming faces as surfaces as shown in images.
    And this only applies to bent sections - the rest can be trimmed with standard frame generator tools.
  8. #18
    Junior Member
    Inventor 2011
    Jan 2010
    22
    Yes, I understand that. Thank you very much! Your solution help me lot. Did all sculp job.
    In previous question I was talking about different things. What to do with assambly file and there generated tubes. How to made them as parts? Here are my question again:
  1. 1st angle/3rd angle projection
    By Lazer in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 30th Jun 2011, 02:09 pm
  2. 3d bended text
    By omid_221 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Nov 2009, 09:27 am
  3. Bended pipe folding?
    By kinglevel in forum Autodesk Inventor
    Last Post: 24th Jun 2009, 02:04 pm
  4. Angle dimension
    By Laurel in forum Autodesk Inventor
    Last Post: 24th Jun 2009, 02:01 pm
  5. Angle of an arc
    By kanyakumari_t in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Jul 2006, 08:50 am
