try 'dimtfillclr'
Hi,
I'm using 2010 and my dimensions text is creating a background mask, I have tried selecting 'none', I have tried 'TEXTFILL' and DIMTFILL- but nothing seems to work.
Can't find anything else on any other forums that describe this problem.
Has anyone got any suggestions?
try 'dimtfillclr'
"An architect's most useful tools are an eraser at the drawing board & a wrecking bar at the site."
Frank Lloyd Wright
TEXTFILL here not and,
DIMTFILL-> 1, should help, but only for again created
As look at the dimension at property panels, in section the Text, colour of filling. What there?
Or show a file where a problem
On this site I not only study AutoCAD but I also practice my English. If you find rough grammatical errors in my messages, please inform me with a personal message.
Dimtfillclr doesn't work
textfill dosen't work
dimtfill doesn't work
What else do you have?
Dorian Gray , Well, show us the file where at you a problem and then we can precisely tell (probably even I will show) what and how it is necessary to make.
Look at the dims and even if you try and turn the color fill to none it still shows wipe background.
Thanks
so no response means you can't fix the problem?
It works fine here, I use background or none for color and it goes away.
What color do you use for your screen background? I use black and don't see a problem. I switched to white and had to force a regen, no longer showing there as well.
"You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
it is certainly happening over here and its quite frustrating, does anyone else have a possible solution????![]()
I just opened the Dimension Style Manager, set the Fill color to None and problem solved. I'm not sure why it doesn't work for you though.
"Work Smart, Not Hard"
Click to View My Portfolio ( Updated 05/21/2013 ) ---> http://www.rdeweese.com/
