Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 38
    Junior Member
    not applicable
    Dec 2009
    13
    Arrow Modifying Schedule Lisp. Please help.
    Can anyone modify the following lisp for me? I found it on cadalyst and its almost what I need, but I would like a little more functionality.
    Here's how it works:
    1) I have a block, that I use as a label, named key-plant and it has 2 attributes: planttype and quantity. "Planttype" is the symbol/code that represents a certain plant species and "quantity" is the quantity that I assign to a group of certain plant blocks.
    2.) I use this "key-plant" block with a leader and label all of my plant blocks.
    3.) I run it typing "pll" and it gives me a plant list in a notepad document...example shown below:
    PLANT-TYPE QUANTITY
    AM ............. 19
    CS .............170
    PA ...............4
    PCA ..............2
    VL ...............78
    cas ..............490
    Here are my questions/requests:
    1.) The lisp currently just throws together a comprehensive list of all blocks in the drawing. I want to add one more attribute like - "Category" - to the "key-plant" block so that I can organize the plant list by the following plant categories:
    -Deciduous Shade Trees
    -Ornamental Trees
    -Evergreen Trees
    -Deciduous Shrubs
    -Evergreen Shrubs
    -Perennials and Ornamental Grasses
    2.) I'd like the list to output in that order (shown above) and then alphabetize for each category.
    3.) I'd like to output to an excel file instead of a notepad file.
    Can anyone help me with this? I know this is very specific, but It would really make my work a lot more efficient. There are so many gurus here and I'm a total noob to Lisp code.
    This is what the "ideal" output would look like:
    PLANT-TYPE QUANTITY
    AM .................19
    CS .................170
    Ornamental Trees
    APB .................4
    BN ...................78
    Evergreen Trees
    PA................... 490
    PGD ................. 25
    etc...etc...
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,405
    I wrote this a while back, untested, but give it a go:
    Code:
    ;; Summing Attributes Before Extraction
    ;; By Lee McDonnell
    (defun c:AttSum (/ ss ofile file attlst x y lst)
      (vl-load-com)
      (if (and (setq ss   (ssget "_X" '((0 . "INSERT") (2 . "KEY-PLANT") (66 . 1))))
               (setq file (getfiled "Output File" "" "csv" 9)))
          (setq ofile (open file "a"))
          (write-line (strcat (getvar "DWGPREFIX") (getvar "DWGNAME")) ofile)
          (write-line "ITEM,QUANTITY" ofile)
          (setq attlst
            (mapcar
              (function
                (lambda (x)
                  (mapcar
                    (function vla-get-TextString) x)))
              (mapcar
                (function
                  (lambda (x)
                    (vl-sort x
                      (function
                        (lambda (x1 x2)
                          (< (vla-get-TagString x1)
                             (vla-get-TagString x2)))))))
                (mapcar
                  (function
                    (lambda (x)
                      (vlax-safearray->list
                        (vlax-variant-value
                          (vla-getAttributes x)))))
                  (mapcar
                    (function vlax-ename->vla-object)
                      (mapcar (function cadr) (ssnamex ss)))))))
          (while (setq x (car attlst))
            (if (setq y (assoc (car x) lst))
              (setq lst (subst (append y (cdr x)) y lst))
              (setq lst (cons x lst)))
            (setq attlst (cdr attlst)))
          (foreach x lst
            (write-line
              (strcat (car x) (chr 44)
                (rtos
                  (apply (function +)
                    (mapcar (function distof) (cdr x))))) ofile))
          (write-line "-----,-----" ofile)
          (close ofile))
        (princ "\n<!> No Blocks Found <!>"))
      (princ))
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Junior Member
    not applicable
    Dec 2009
    13
    Works great but..... can you make it organize/alphabetize the excel output based on a third attribute named "category" ?
    Thanks for your help Lee.
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,405
    Perhaps.
    Would you be able to upload an example of the block you are using?
  5. #5
    Junior Member
    not applicable
    Dec 2009
    13
    Sure...give me 2 minutes.
  6. #6
    Junior Member
    not applicable
    Dec 2009
    13
    oops...completely forgot the last 4 categories (groundcovers, vines, annuals, seed mixes)
    So the final excel output should have the following categories in the following order and alphabetized per category.
    -Ornamental Trees
    -Evergreen Trees
    -Deciduous Shrubs
    -Evergreen Shrubs
    -Groundcovers
    -Vines
    -Annuals and Bulbs
    -Seed Mixes
    One last request....Would it be possible to get a selection set prompt so I can selectively choose which blocks I'd like to get this info from? Could I use a polyline boundary for this selection set.?
  7. #7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,405
    Didn't see your last request, but try this for the first part:
    Code:
    (defun c:AttSum (/ *error* Get_Unique ATTLST CAT CAT_TAG ENT FILE I
                                 N NUM NUM_TAG OBJ OFILE SS SYM SYM_TAG)
      (vl-load-com)
      ;; Lee Mac  ~  01.02.10
      (setq Cat_Tag "CATEGORY"
            Sym_Tag "SYMBOL"
            Num_Tag "QUANTITY")
      (defun *error* (msg)
        (and ofile (close ofile))
            (princ (strcat "\n** Error: " msg " **")))
        (princ))
      (defun Get_Unique (lst / Remove_n x ass result)
        (defun Remove_n (n lst)
          (setq i -1)
          (vl-remove-if
            (function
              (lambda (x) (= (setq i (1+ i)) n))) lst))
        (while (setq x (car lst)) (setq lst (cdr lst))
          (while (setq ass (assoc (car x) lst))
            (setq x (cons (car x) (append (cdr x) (cdr ass))))
            (setq lst (Remove_n (vl-position ass lst) lst)))
          (setq result (cons x result)))
        result)
      (mapcar (function set) '(Cat_Tag Sym_Tag Num_Tag)
              (mapcar (function strcase) (list Cat_Tag Sym_Tag Num_Tag)))
      (if (and (setq i -1 ss (ssget '((0 . "INSERT") (2 . "KEY-PLANT") (66 . 1))))
          (write-line "PLANT-TYPE,QUANTITY" ofile)
          (while (setq ent (ssname ss (setq i (1+ i))))
            (setq obj (vlax-ename->vla-object ent))
            (foreach att (vlax-invoke obj 'GetAttributes)
              (cond (  (eq Cat_Tag (strcase (vla-get-TagString att)))
                       (setq Cat (vla-get-TextString att)))
                    (  (eq Sym_Tag (strcase (vla-get-TagString att)))
                       (setq Sym (vla-get-TextString att)))
                    (  (eq Num_Tag (strcase (vla-get-TagString att)))
                       (setq Num (vla-get-TextString att)))))
            (if (and Cat Sym Num)
              (setq AttLst (cons (cons Cat (list (cons Sym (list Num)))) AttLst))))
          (setq AttLst (vl-sort (mapcar
                                  (function
                                    (lambda (x)
                                      (cons (car x)
                                            (vl-sort (Get_Unique (cdr x))
                                              (function
                                                (lambda (a b)
                                                  (< (car a) (car b)))))))) (Get_Unique AttLst))
                                (function
                                  (lambda (a b)
          (foreach x Attlst
            (write-line (car x) ofile)
            (foreach y (cdr x)
              (write-line
                (strcat (car y) (chr 44)
                  (rtos
                    (apply (function +)
                      (mapcar (function distof) (cdr y))))) ofile))
            (write-line "" ofile))
          (setq ofile (close ofile)))
      (princ))
    EDIT: Updated as per last request
  8. #8
    Junior Member
    not applicable
    Dec 2009
    13
    This is almost dead on...You sir are a genius!
    The category names showed up alphabetized, but I need them in this specific order:
    -Ornamental Trees
    -Evergreen Trees
    -Deciduous Shrubs
    -Evergreen Shrubs
    -Groundcovers
    -Vines
    -Annuals and Bulbs
    -Seed Mixes
    What I need alphabetized is the content in each category.
  9. #9
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,405
    Quote Originally Posted by mexmr10 View Post
    -Ornamental Trees
    -Evergreen Trees
    -Deciduous Shrubs
    -Evergreen Shrubs
    -Groundcovers
    -Vines
    -Annuals and Bulbs
    -Seed Mixes
    You don't ask for much...
  10. #10
    Junior Member
    not applicable
    Dec 2009
    13
    Im sorry...and I really appreciate your help.
    Ok would it work if I inserted a number in front of each category name so that it would read the number first instead of the first letter?
  1. Help modifying lisp for sqft
    By vladthedog in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Oct 2009, 12:42 am
  2. Modifying Dimension Style using lisp
    By briankstan in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Aug 2009, 06:11 pm
  3. Modifying layers with lisp
    By Henryjohn in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Jan 2009, 12:16 pm
  4. Help Modifying LISP (Break Routine)
    By herkenbrack@gmail.com in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Aug 2008, 03:32 pm
  5. Help Modifying LISP that copies attribues
    By icevapor in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Jun 2008, 02:48 pm
