Results 1 to 3 of 3
    Full Member
    AutoCAD 2008
    Jun 2009
    28
    Question VBA SetXData to Entity Error
    I am trying to Set Xdata to a object in a drawing, but indicates me that the method is failling, I am trying to understand how xdata works, if someone can tell what i am doing wrong...
    thanks in advance
    Code:
    Sub InputXData()
        Dim AppNames() As String
        Dim ANIsHere As Boolean
        Dim Tn As String
        Dim i As Integer
        ANIsHere = False
        For i = 0 To ThisDrawing.RegisteredApplications.Count - 1
            ReDim Preserve AppNames(i)
            AppNames(i) = ThisDrawing.RegisteredApplications.Item(i).Name
            If AppNames(i) = "Panel_Data" Then ANIsHere = True
        Next
        If ANIsHere = False Then
            ThisDrawing.RegisteredApplications.Add ("Panel_Data")
        Else
        End If
        Dim TheObj As AcadObject
        Dim xType(20) As Integer
        Dim xValue(20) As Variant
        Dim ssetObj As AcadSelectionSet
        On Error Resume Next
        ThisDrawing.SelectionSets("SS01").Clear
        ThisDrawing.SelectionSets("SS01").Delete
        On Error GoTo 0
        Set ssetObj = ThisDrawing.SelectionSets.Add("SS01")
        ssetObj.SelectOnScreen
        Set TheObj = ssetObj.Item(0)
        xType(0) = 1001: xValue(0) = "Panel_Data":
        xType(1) = 1000: xValue(1) = "HH42" 'Name
        xType(2) = 1050: xValue(2) = "hr4524c" 'Linked to label
        xType(3) = 1070: xValue(3) = 3 ' total number of items
        xType(4) = 1000: xValue(4) = "hr4524c"
        xType(5) = 1070: xValue(5) = 1 ' position
        xType(6) = 1000: xValue(6) = "c32r25" ' obj1 handle
        xType(7) = 1000: xValue(7) = "No Info" ' obj2 handle
        xType(8) = 1000: xValue(8) = "No Info" ' obj3 handle
        xType(9) = 1000: xValue(9) = "No Info" ' obj4 handle
        xType(10) = 1000: xValue(10) = "No Info" ' obj5 handle
        xType(11) = 1000: xValue(11) = "hr4524c" ' Label1 handle
        xType(12) = 1000: xValue(12) = "No Info" ' Label2 handle
        xType(13) = 1000: xValue(13) = "No Info" ' Label3 handle
        xType(14) = 1000: xValue(14) = "No Info" ' Label4 handle
        xType(15) = 1000: xValue(15) = "No Info" ' Label5 handle
        xType(16) = 1000: xValue(16) = "HH" ' Batch
        xType(17) = 1000: xValue(17) = "3L" ' Material
        xType(18) = 1000: xValue(18) = "3mm"
        xType(19) = 1000: xValue(19) = "white"
        xType(20) = 1000: xValue(20) = "C:\Drawings\Example.dwg"
        TheObj.SetXData xType, xValue
        If Err.Number <> 0 Then
            MsgBox Err.Number & vbCr & Err.Description
            On Error GoTo 0
        End If
        ssetObj.Clear
        ssetObj.Delete
    End Sub
    Super Member SEANT's Avatar
    AutoCAD 2012
    Aug 2005
    Rhode Island
    1,968
    This line is causing a problem. Should it actually be a 1050 group code?
    Code:
    Full Member
    AutoCAD 2008
    Jun 2009
    28
    That is correct SEANT, it should be :
    Code:
    xType(2) = 1005: xValue(2) = "hr4524c" 'Linked to label
    Thank you !
  1. DBX entity select mod
    By ollie in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Oct 2009, 09:19 am
  2. Get Sub Entity
    By mcguirepm in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Jun 2009, 05:12 pm
  3. New Entity Type
    Last Post: 3rd Oct 2008, 05:46 pm
  4. Append entity name
    By P Zero in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Jul 2008, 07:34 pm
  5. Entity Properties
    By bikerblayne in forum AutoCAD Beginners' Area
    Last Post: 23rd Oct 2007, 10:43 pm
