Trying to create a chamfer.
Timms_KHP
Hi all,
i'm trying to create a chamfer between a concrete slab and concrete upstand/parapet wall.
Its above the stair so the chamfer will create the min 2.0m headroom clearance, (required in the uk). how do i do this?
picture attached, hopefully.
Chamferdetail.jpg[/img]
First, determine what the slanted section BEST represents: an up-slanted slab, or a down-slanted wall.
Once you have determined this, you can the put in a separate slanted wall or slab and simply use Join to blend things together
There are various ways to get a slanted component: slabs can have the edges manipulated and sloped, you could pick a slanted line or plane as a guide line and use it to place the wall... etc...
If you're in Revit 2010, I know you can set a split line and then use the manipulative options for slabs to move edges around and use the split line as a pivot point.
Let me know if you need more help, a vid or pictures.
Good luck!
