Results 1 to 4 of 4
    Full Member T9PMK's Avatar
    T9PMK's Computer Details
    Window XP Pro - Vista Business - Vista Ultimate - Windows 7
    Dell 755 and a high spec home build
    3Gig
    3x 22" Dell Monitors using UltraMon
    AutoCAD LT 2010
    Mar 2005
    Yorkshire - UK
    41
    Default Dynamic Block - Help Requird
    This block is doing my head in now so can someone please take a look.
    The problem is when i try and adjust for way thickness one of the other arrow moves.
    Thanks in advance
    T9
    Super Member Pablo Ferral's Avatar
    Inventor 2010
    Feb 2005
    London
    571
    How about this version?
    3Gig
    AutoCAD LT 2010
    Mar 2005
    Yorkshire - UK
    41
    Thanks for your reply and your version.
    It's quite hard to get all the grips following rotate, stretch & flip isn't it.
    I have amended my original posted block and it new works a lot better with a Visibility set to switch between Left & Right swing, all grips follow rotation etc.
    All I require now is a flip for inward/outward opening.
    If I can get this block fully working I shall try Double, Door + Half Leaf.
    Lastest block attached, try this one.
    Cheers T9
    3Gig
    AutoCAD LT 2010
    Mar 2005
    Yorkshire - UK
    41
    Door & Half Leaf Attached.
    Cheers T9
  1. Dynamic block with dynamic attributes
    By Helenka in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jul 2012, 09:56 am
  2. dynamic insert of a dynamic block.
    By Huibert in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jun 2010, 02:12 am
  3. multiple dynamic constraints in a dynamic block
    Last Post: 16th Jul 2009, 11:13 am
  4. Replies: 5
    Last Post: 26th Jun 2009, 04:50 pm
  5. Dynamic block to dynamic ?
    By OMEGA-ThundeR in forum AutoCAD Drawing Management & Output
    Last Post: 1st May 2009, 11:04 am
