Results 1 to 4 of 4
    Senior Member CJJ's Avatar
    CJJ's Computer Details
    Windows XP
    Old, Slow, Full of porn.
    Civil 3D 2009
    Nov 2009
    North Carolina
    137
    Exclamation "Unable to execute the tool" error
    I saw a similar thread, but it was unrelated so I'm starting a new one.
    Using AutoCAD Civil 3D 2009, trying to access the tool palettes for roadway corridor assemblies. The TP will load correctly, and the images/text on the pallet are there, but when I try to drag an entity from the pallet into the drawing, I am getting the following message:
    Unable to execute the tool. Possible Causes are:
    - Tool is not registered properly...
    - Tool is from another application...
    The first thing I did was try to reload the profile and make sure there wasn't a problem there, and that didn't fix the problem. I've checked my paths and everything seems to be pointing to the right places. Since the pallet itself loads, i don't think the problem is with paths, but i don't know for sure. These pallets are the default imperial roadways that came with C3D so i don't think the problem is related to application incompatibility, so I'm wondering if it has to do with the tool not being registered properly.
    How do I check this? How do I register a tool, or troubleshoot registration errors?
    Has anyone had this problem before or have any other ideas on how to fix it?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,144
    Is there a RegisteredTools folder for Civil 3D? If so what's in it or is it completely empty?
    Windows XP
    Civil 3D 2009
    Nov 2009
    North Carolina
    137
    There are two files:
    ADTMtlStockTools.atc and C3DStockTools.atc
    Forum Newbie
    AutoCAD 2011
    Dec 2010
    1
    http://forums.autodesk.com/t5/AutoCA...ed/m-p/2308357
    Here I found a way which worked and solved the problem. In short: re-activate the secondary installer which installs the Autodesk product when a local user starts it for the first time. To achieve this delete the appropiate key from the registry and delete the appropiate directories and all its contents from the users Document and settings. All your custom settings will vanish unless you save those files and settings previously.
  1. Block "NAME" is not found in the source drawing. (Tool Pallets)
    By SuperCAD in forum AutoCAD Drawing Management & Output
    Last Post: 24th Sep 2009, 11:44 pm
  2. Replies: 2
    Last Post: 6th Nov 2008, 07:33 pm
  3. Unable to Execute the tool
    By Rhayes in forum AutoCAD Drawing Management & Output
    Last Post: 5th Sep 2007, 05:54 pm
  4. AutoCAD Express Tool System Variable Editor "SYSVDLG"
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 17th Jan 2007, 08:00 pm
  5. Unable to save file "command in use"
    By Scale in forum AutoCAD Drawing Management & Output
    Last Post: 17th Jul 2006, 03:02 pm
