Results 1 to 6 of 6
    Full Member
    Civil 3D 2011
    Nov 2009
    Somewhere between heaven and hell
    63
    Default Dynamic block with attributes
    My drawing has a block named "Revision" which is a dynamic block with 9 visibility states. Other than the 'No Revision Display' state, all other visibility states have one text line (a simple mtext) and more than one attributes.
    The mtext and each attribute is set to:
    Annotation: yes
    Annotation scale: 1:1000 & 1:1_1
    I have no problem with the mtext but the attributes did't show up when I used the above setting. When I changed to no annotation, the attributes showed up. Why is that?
    Note: the block is inserted as part of the title block in Layout which is has 1:1_1 annotation scale.
    Thanks.
    Super Member Pablo Ferral's Avatar
    Inventor 2010
    Feb 2005
    London
    571
    Can you post your block?
    Full Member
    Civil 3D 2011
    Nov 2009
    63
    How do I post my block here? I've never done it before.
    Inventor 2010
    Feb 2005
    London
    571
    Click' Go Advanced' and look under 'Additional options...
  5. #5
    Full Member
    Civil 3D 2011
    Nov 2009
    63
    Like this?
  6. #6
    Inventor 2010
    Feb 2005
    London
    571
    That's the ticket. Your block seems to operate as described on my machine. I have three tips for you to try when dealing with attributes and the block editor.
    1. Use the 'BATTMAN' Command to sync your attributes.
    2. If your block is dynamic, right click on it and choose 'Reset Block'
    3. Re-Insert the block.
    One of these options should help your new attribute definitions show up...
  1. Dynamic block with dynamic attributes
    By Helenka in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jul 2012, 09:56 am
  2. Dynamic Block Attributes
    By Chad_bestmnf in forum AutoCAD General
    Last Post: 14th Oct 2009, 05:36 pm
  3. (not) Editing attributes in a dynamic block
    By MaxwellEdison in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 19th Dec 2008, 07:27 am
  4. VBA: choosing dynamic block attributes
    By CADenator in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Aug 2008, 04:34 am
  5. dynamic block attributes?
    By maxholer in forum AutoCAD General
    Last Post: 25th May 2005, 12:59 pm
