"Attempting to Cancel"
dwelch
I have attached a .jpg file to my project. It is a scan of a plan. I am drawing over it. When I attempt to plot it, I briefly see the message "Attempting to Cancel". The sheet then comes out of the printer blank. Same thing happens if I try to print as a .pdf, a blank .pdf is produced. I just did this same thing a month or so ago and it worked fine. Nothing has changed as far as hardware or software since then. Any thoughts?
I had a problem like that at a previous firm. The problem we had was not enough memory at the printer end. Does it print OK with smaller files?
Could be your printer driver - some postscript (PSL*) drivers have trouble with pdfs and bitmaps; they are optimised more for text than graphics.
I have had this problem in the past and just changed the printer driver to a PCL6 driver which solved the problem.
