ReMark Posted August 12, 2016 Share Posted August 12, 2016 There really is no good reason to put anything on the Defpoints layer that doesn't belong there since the introduction of being able to set a layer to "no print" in the Layer Property Manager. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted August 12, 2016 Share Posted August 12, 2016 I remember using 2007 and if layer zero was frozen you were not able to select the viewport layer if it was on defpoints. The above is correct, except the phrase "viewport layer"? I think you just meant to say "viewport". Already noted this here. Quote Link to comment Share on other sites More sharing options...
MillerMG Posted August 12, 2016 Share Posted August 12, 2016 Yes sir. Did not mean to put viewport layer. Just meant viewport. You link was spot on. Looks like I just repeated what was already said. Quote Link to comment Share on other sites More sharing options...
rkent Posted August 12, 2016 Share Posted August 12, 2016 Then that has changed over the years. Pre A2K everything is visible. I did write that a long time ago. -David Just opened 2002 and checked it out, can confirm that the defpoints dots on dimensions continued to show whether the layer was frozen, turned off, or both. Quote Link to comment Share on other sites More sharing options...
