I initially tried to make a complex linetype, but then found the MEASURE command. I make a block of the correct hedge thickness, and send it along the hedge centre line, which I then erase.
However, I don't know whether 2000LT has the Measure command, and you may have to resort to a complex linetype. It may be easier to define a shape, then use that in the linetype.
