viriato79 Posted February 15, 2010 Share Posted February 15, 2010 What is the purpose of the Global Widht value for a poliline? What is the relation of this with the ineweight of the polyline? Thanks Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 16, 2010 Share Posted February 16, 2010 We use polyline width for fat lines versus normal drafting pen weights 0.18,0.24.0.35 etc just set polyline to normal pen weight then other objects can be on same layer. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 16, 2010 Share Posted February 16, 2010 There are three ways to assign width to a polyline. 1) Start the polyline command, pick your start point BUT before picking the next point type W (for width) and specify both the starting and ending width. 2) Draw the polyline first, without designating a width, then use the Pedit command and the Width option. 3) Use the Plinewid command to set the width of all polylines drawn after the command is issued. This variable will not change the width of polylines drawn previously. AutoCAD default lineweight width is 0.25mm which is equal to one pixel. Lineweight width is controlled by the system variable LWDEFAULT. Lineweight "Lineweights are width values that are assigned to graphical objects as well as some types of text." Quote Link to comment Share on other sites More sharing options...
rkent Posted February 16, 2010 Share Posted February 16, 2010 What is the purpose of the Global Widht value for a poliline? What is the relation of this with the ineweight of the polyline?Thanks Polyline with a width of zero will use the global line width, Polyline with a width greater than zero and the global line width is ignored and the pline width is used. Quote Link to comment Share on other sites More sharing options...
