Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Senior Member
    AutoCAD 2006
    Jul 2008
    116
    Default unable to explode block
    Hi to all my fellow caddies. I need some helpfrom you guys regarding the block that i cannot explode. I try to explode the block several times but cannot be explode. What to do with this block? Thanks
    Senior Member DNK's Avatar
    DNK's Computer Details
    Win 7 Ent
    See details...
    DNK's Discipline Details
    Contractor
    See details below.
    Broadcast Engineering
    AutoCAD 2011
    Feb 2010
    ATL
    160
    Enter in the Block command. Find the block name of the block you need to explode. On the right hand side, select the check box next to "Allow Exploding". Click OK. The block can now be exploded.
    It may also insert that block at 0,0 after redefinition.
    Super Member
    AutoCAD pre 2000
    Nov 2008
    577
    Quote Originally Posted by rengised View Post
    Usually you get an error message that something is wrong, like when trying to explode an XREF, a mirrored block or.....
    What does the error message say then, as to why block cannot be exploded?
    Wm.
    Senior Member
    AutoCAD 2006
    Jul 2008
    116
    Default Thanx
    Thanx for the reply buddies. I still cannot explode the block. Attached the block so that you can see guys. Thanx
  5. #5
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    I couldn't explode it either but I found a work around. Enter the block editor, copy all to your clipboard, close block editor, and paste into your drawing.
    Drafting is a breeze.
  6. #6
    Senior Member
    AutoCAD 2006
    Jul 2008
    116
    RobDraw, thanx for the tips and quick reply and it works. Thanx very much. But im still wondering if there is any soulution how to explode this block...
  7. #7
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Yeah, me too.
  8. #8
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    I just opened your block and followed the suggestion DNK gave and it exploded for me.
  9. #9
    Senior Member
    AutoCAD 2000
    Nov 2008
    182
    Quote Originally Posted by RobDraw View Post
    If you could do that, then refset>>remove and save changes to block. After that you can delete the block and the removed objects will become exploded.
    We learn more by looking for the answer to a question and not finding it than we do from learning the answer itself. ~Lloyd Alexander
  10. #10
    Senior Member
    AutoCAD 2006
    Jul 2008
    116
    lpseifert, it works, dnk thanks also, thanks all to those who help and replied to me. very much appreciated....
  1. Can't explode block
    By NiceGuy8618 in forum AutoCAD Beginners' Area
    Last Post: 10th Jan 2013, 09:51 am
  2. Explode block placed with VBA
    By wbluem88 in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Feb 2010, 11:30 pm
  3. Explode block / explode text command
    By repelectric in forum AutoCAD General
    Last Post: 3rd Aug 2009, 09:52 pm
  4. Explode Block
    By vinod in forum AutoCAD General
    Last Post: 23rd Sep 2008, 08:40 am
  5. explode block
    By wastewater in forum AutoCAD Drawing Management & Output
    Last Post: 27th Oct 2006, 05:03 pm
