Results 1 to 5 of 5
Thread: SaveAs New Name
    Forum Newbie
    Map 3D 2010
    Feb 2010
    8
    Default SaveAs New Name
    Thanks in Advance I am New to this forum
    I need to save a file with the same name but add something like Plot_ at the beginning of the name also saved in an older version
    Problem: To view certain elements in AutoCad 2010 that were creaed in Civil3d 2010, I had to save the file in an older version of Autocad. I saved it as AutoCad 2000 it seemed to work.
    So if the design Engineer can save thier drawing and also at the same time save a copy with the same name but have Plot in front of the DWGNAME
    This below works but saved file is Hard Coded in it.
    (vl-load-COM)
    (vla-SaveAs (vla-get-ActiveDocument(vlax-get-acad-object)) "test1.dwg" ac2000_dwg)
    Correct me if I am wrong. DONT ANYONE LAUGH (Outloud that is
    I need to get the DWGNAME
    Maybe through getvar
    (setq name (getvar "DWGNAME"))
    (setq plot "plot_")
    strcat these together some how
    and place in this code
    (vl-load-COM)
    Does anyone have a complete answer?
    Thanks Again
    A Newb to Lisp
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,743
    You pretty much had it, nice one:
    Code:
    (vl-load-COM)
      (strcat (getvar "DWGPREFIX") "plot_" (getvar "DWGNAME"))
      ac2000_dwg)
    Lee Mac Programming
    Just another Swamper
    Forum Newbie
    Map 3D 2010
    Feb 2010
    8
    That is Perfect.
    Forum Newbie
    Map 3D 2010
    Feb 2010
    8
    Thank You so much
  5. #5
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,743
    Quote Originally Posted by chomuth View Post
    Thank You so much
    No worries, you did most of it
    Lee Mac Programming
  1. Saveas
    By FazBear in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th May 2009, 12:07 pm
  2. Saveas dwgname_rev1
    By jbergoon in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Aug 2008, 10:05 pm
  3. SaveAs() VBA function
    By opelit in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Nov 2006, 02:41 pm
  4. Saveas - dated folder
    By AWOL in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Apr 2005, 07:15 pm
  5. SaveAs Dwg in an earlier version
    By Maurice Williams in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jun 2004, 11:32 pm
