Results 1 to 3 of 3
    Forum Newbie
    AutoCAD 2008
    Feb 2010
    2
    Embarrassed Layer States & Viewports
    Autocad 2008. Have several layout tabs in Paper Space, each has their own viewports with specific layers frozen & thawed. ("VPFREEZE" column in Layer Prop Mgr) so that each viewport has it's own unique "Layer States" setting. Used LMAN to create settings for each one.
    When in Model Space, if any other LMAN setting is used, the viewports do not retain their unique layer settings. I've made sure that the "viewport overrides" is not checked.
    Essentially, each time the drawing's layer settings are changed in either model space or even in separate layout tabs, I have to manually go back to each layout tabs' viewports and re-set Layer settings before each plot. Very cumbersome. HELP!
    How can I lock the unique Layer Settings assigned to each viewport?
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Look here for Loswitch.dvb
    http://www.dotsoft.com/freestuff.htm
    It will switch Layerstates per Layouts, not viewports...
    Forum Newbie
    AutoCAD 2008
    Feb 2010
    2
    this works great. thanks!
  1. Layer States
    By Lithium in forum AutoCAD Beginners' Area
    Last Post: 26th Feb 2009, 05:42 am
  2. Autocad LT 2009: X-ref layer states / Layer states manager
    By Mako in forum AutoCAD Drawing Management & Output
    Last Post: 6th Nov 2008, 04:24 pm
  3. Layer States
    By Rhayes in forum AutoCAD Drawing Management & Output
    Last Post: 18th Mar 2008, 06:09 am
  4. Layer States
    By johnengineer in forum AutoCAD Beginners' Area
    Last Post: 7th Sep 2007, 10:55 pm
  5. Layer States
    By danny_macd in forum AutoCAD Drawing Management & Output
    Last Post: 5th Jun 2006, 04:33 pm
