Movie Making Software
David Bethel
I'm currently using Bink to compile and compress my images into a movie ( .exe )
http://www.radgametools.com
I've tried Paintshop Pro Animation and various slide show makers without a lot of luck.
Bink does fairly good but the frame to frame transition can leave a bit to be desired. ( it is focussed more for gaming software )
Anyone have any software suggestions:
30-33 frames per second
1024 x 768 frames ( TGA BMP or JPG )
1,000 to 3,000 frames
File size compression is not an issue
Looking for best quality video
TIA -David
I had to save the project I was working on after each change to prevent crashing repeatedly. Once I up graded the ram on my workstation, I have not had a problem with crashing.
