try PDFFRAME for PDF's.
Set it to 0 for no frame, 1 for the frame, and 2 to see the frame but it won't plot.
Good afternoon all,
I'm creating a cover sheet for a drawing set, and I would like I add some PDF images to it. I had no problems x-refing them into the sheet, but because all images have to be assigned a layer, all of the PDFs are bordered by a line of that layer's weight and color.
I tried to assign the layer "do not plot", but the images don't plot either when I do. Is there a way to x-ref a PDF image into my sheet and prevent the border line from printing? I'm using AutoCAD 2010. Thanks for the help!
Tannar Frampton | Facilities Engineering | Revit 2013
Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
hey, it worked! Thanks a lot!
Also imageframe should work too. I never heard of PDFRAME. Thanks!
Here's all the info needed for anything having to do with "Frames". Think of the FRAME command as the global setting for all items that consist of frame borders. And glad you found this useful.
http://exchange.autodesk.com/autocad...08800e3ca5.htm
Code:The FRAME setting overrides the individual IMAGEFRAME, DWFFRAME, PDFFRAME, DGNFRAME, and XCLIPFRAME settings. 0 The frame is not visible and it is not plotted. The frame temporarily reappears during selection preview or object selection. 1 Displays and plots the frame. 2 Displays but does not plot the frame. 3 The individual setting varies for all external references in the current drawing (images, underlays, and clipped xrefs all have different frame settings).
Excellent. Thank you again, you really bailed me out today!
