Results 1 to 2 of 2
    Junior Member
    not specified
    Oct 2005
    Lethbridge, AB
    11
    Default Databasing a directory of drawings
    I am fairly new to VBA programming, and am working for an Engineering firm, who has thousands of drawings saved in a 5 tier directory hierarchy structure. I am making an Access database in which the titles, client, drawing type, and some information specific to each drawing is saved in each record.
    Does anyone know of a way to search through the entire directory structure, fetch the drawing name, and one common attribute from the titleblock? I am trying to save at least a little time from the clerk's duties.
    Also it would be nice to include a link on each record to the full path/filename and update a voloview control within the form for each drawing/record. I'm sure this part is quite easy, and already have a good idea of how to do it.
    I know this will not be easy, nor will it be quick upon first run.
    The program could be an Access macro, or AutoCad 2002 VBA program. I also have at my disposal VB 6 and VC++ 6.
    Any ideas, thanks, or comments are greatly appreciated.
    This is a computer generated message. It needs no further signing.
    Senior Member
    not specified
    Sep 2005
    Brisbane, Australia
    318
    I have a macro that would basically do what you're after...it can process (Update the titleblocks of drawings in a selected folder) with out opening each file into the autocad browser.
    PM me to discuss it further.
