Exploding Mtext makes result scaled down and thrown across the screen
Shandley
Greetings,
I am not what you would call a noob but I am self taught. This being said, I have been playing with Autocad for about 8 years now and I use it daily at work.
I am trying to explode some text using txtexp. When I do that, it does explode but it scales it to just over 1/25th the size and sends it off to the upper right of the screen.
This doesn't happen EVERY time but there is no rhyme or reason to it. I tired Autocad 2004, 2006, and 2007. I tried individual texts and multiple.
Here is a couple photos of the issue:
BEFORE
AFTER - You can see the text in the upper right corner as a bit of a white blur
Pardon my ignorance but what is that?
Pardoned. :)
Command: 7 LIST 1 found
                 MTEXT     Layer: "0"
                           Space: Model space
                  Handle = 45299
            Style = "EXISTING"
       Annotative: Yes
 [color=Red]Annotative scale:  1" = 100'[/color]
Width:                0.00
Normal:          X=     0.00  Y=     0.00  Z=     1.00
Rotation:           0d0'0"
Paper text height:          0.08
Model text height:          8.00
Line spacing:    Multiple (1.000000x =      0.13)
Attachment:      TopLeft
Flow direction:  ByStyle
Contents:        text
I do not think so.
list
1 found
                 MTEXT     Layer: "0"
                           Space: Model space
                  Handle = cb
Width:              2.0000
Normal:          X=   0.0000  Y=   0.0000  Z=   1.0000
Rotation:                0
Text style:      "Standard"
Text height:        0.1750
Line spacing:    Multiple (1.000000x =    0.2917)
Attachment:      MiddleCenter
Contents:        {\fSwis721 BdRnd BT|b0|i0|c0|p34;HOUSE BATTERY\PVOLTS}
I do not think so.
list
1 found
MTEXT Layer: "0"
Space: Model space
Handle = cb
Width: 2.0000
Rotation: 0
Text height: 0.1750
It's not. Doh, I didn't even pay attention to what version you were running. I'm dumb.
Could you get away with exploding the text the executing TXTEXP?
Thats what I used.
I tried just x and I tried the Express, Text, Explode Text (which I think is the same as TXTEXP)
No, I mean to just EXPLODE the MText first (becomes Text). Then TXTEXP them.
Ok, when I EXPLODE the MText, it turns it into the Standard style. I changed the style to the font I want and used the TXTEXP command but it does the exact same thing.
