Design centre
Jadgpanther
Hi all
I have new 2010 LT,
in design centre when I add items to the 'favourites' , it does not show in design centre favourites window, even after refresh. ( but the added items do show up in the favourites fold under windows ???)
any ideas,
I tried to reproduce your problem but failed. I too have a Projects folder. I went to the location on my hard drive where the folder is stored. I right-clicked on it and selected Add to Favorites. I then went to the top of the Design Center window, clicked on the Icon for Favorites and in the Content Window there was a shortcut to my Projects folder along with shortcuts to AutoCAD Discussion Groups and AutoCAD Exchange, etc.
Try again. Maybe you missed something.
BTW...I was even able to delete the shortcut to the Projects folder via the Organize Favorites option.
thanks for reply
is weird, when I right click, organise favourites, I can see the newly added link, but not in the actual viewing pane for the design centre favourites,
You should update your CT profile. It still says LT 2005.
I just can't come up with a reason why it works on my system and not on yours. Sorry.
QM
thanks for replies, must be some erroneous bug,
I will see what our Autodesk distributor has to say
thanks again
will update profile
  • 8 months later...
Somewhat of a thread dig here..
Myself and another guy at my work are both on 2011LT and are having the same issue.. I right click on the folder and select "add to favourites" and then refresh the favourites area only to see nothing there. If i right click on the autodesk folder and select "organise favourites" i can see my added dwg's or folders.
