Results 1 to 9 of 9
    Full Member
    peterg's Computer Details
    XP PRO
    AutoCAD 2007
    Jan 2010
    Liverpool, England
    51
    Default Lines & Poly lines
    What is the difference between normal lines & poly lines?
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Professional 64 bit
    HP EliteBook 8570w
    Intel Core i7-3720QM 2.60GHz
    16GB
    NVIDIA Quadro K2000M
    HP
    Civil
    Tiger's Discipline Details
    Education /support
    Civil
    Support/Education/Retail
    Civil 3D 2016
    Nov 2006
    Fjärdhundra, Sweden
    5,148
    A Polyline will form a continous line (i.e. one object) when you keep drawing segments. A Line will form separate objects with each segment.
    MTJIGSTRING = BAZINGA
    Full Member
    XP PRO
    AutoCAD 2007
    Jan 2010
    Liverpool, England
    51
    Default This is my understanding of your answer, is it correct?
    Quote Originally Posted by Tiger View Post
    Normal lines
    If I draw a square (ortho on) absolute starting point, then enter dimensions for each side moving the cursor to form 4 sides, this would be seen as 4 seperate lines.
    polyline
    If I use the same procedure to draw the same square, this would be seen as 1 line.
    HP EliteBook 8570w
    16GB
    HP
    Civil
    Education /support
    Civil
    Civil 3D 2016
    Nov 2006
    Fjärdhundra, Sweden
    5,148
    Quote Originally Posted by peterg View Post
    Normal lines
    polyline
    Yep. Exactly. No need to cry over it
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    Polylines can also be assigned a width.
    Polylines can includes arcs.
    Polylines can have a curve fit to them or be splined.
    Moving, rotating, copying, mirroring, etc. an object created with polylines (continuous) is usually easier than if the object is comprised of individual lines.
    Non-continuous polylines, as well as lines, can be "joined" using the Join command or the Pedit command.
  6. #6
    Super Member Patrick Hughes's Avatar
    Patrick Hughes's Computer Details
    Win 7 x64
    Dell Precision T7610
    Intel Xeon E5-2630 v2 (six core)
    32 Gb
    3 Gb Nvidia Quadro K4000
    1 TB
    2x 1920x1080 Dell Ultrasharp U2312HM
    Mechanical
    Patrick Hughes's Discipline Details
    Self unemployed - Machine Design
    Mechanical
    Machine Design
    AutoCAD 2015
    May 2008
    Rockford, Illinois
    763
    Normal lines
    polyline
    Heh heh, good question.
    You will see the same rectangle - the "line" rectangle will be made of 4 lines.
    The "polyline" rectangle will be made of 4 lines that are joined together and are selectable as one object. You can stretch both types. A polyline can be exploded into its individual segments which would then leave you with a 4 line rectangle.
    Conversly a line can be turned into a polyline and joined with other (connected) lines.
    www.cadtempo.com
    Time tracking for AutoCAD, Inventor, Revit and other CAD programs
  7. #7
    Senior Member
    Wilbri's Computer Details
    MS Windows 7 Professional 64Bit
    Self built
    Gigabyte GA-890GPA-UD3H AMD 890GX
    AMD Phenom II X4 965 Black Edition Processor - 3.4GHz
    16 GB DDR3-1600
    None (AMD FirePro V4900-future)
    Samsung® SATA2 1.5 TB 7200RPM 32MB
    Samsung BX2450 Monitor 24" Led
    Mechanical
    Wilbri's Discipline Details
    My own business. Design, Drawing, Cost Estimating and Planning
    Mechanical
    Design Engineer - General mechanical
    AutoCAD 2007
    Dec 2009
    South Africa
    214
    If I understand correctiy drawing a rectangle using the "rectangle" command would produce a "polyline" rectangle.
    I this correct?
  8. #8
    Senior Member
    AutoCAD 2004
    Sep 2004
    Oregon, Usa
    208
    Yes it would.
    A rectangle drawn with the rectangle command is also a " closed polyline" and can be extruded into a solid object.
    Working with the command "Pedit" (polyline edit) can help you better understand about lines and polylines and the difference between closed and open polylines and how to change a line into a polyline etc.
  9. #9
    Senior Member
    Self built
    16 GB DDR3-1600
    Mechanical
    Mechanical
    AutoCAD 2007
    Dec 2009
    South Africa
    214
    a1harps
    Thank you.
    In the past I have produced my drawings using "lines".
    ReMark recently made me aware of the advantages of drawing with "polylines" and using "Pedit", a practice I will be adopting in my next drawing now that I have become
    with it.
  1. 3D Dashed Poly Lines - How to Create
    By NYATI in forum AutoCAD 3D Modelling & Rendering
    Last Post: 10th Sep 2009, 12:04 pm
  2. how to convert normal lines into poly line
    By vidyamangam in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Jul 2009, 12:02 pm
  3. Constructing Hidden Lines and Construction Lines
    By Colgrave in forum AutoCAD Beginners' Area
    Last Post: 6th Feb 2009, 04:01 pm
  4. Replies: 16
    Last Post: 3rd Dec 2008, 03:45 pm
  5. 3d (poly)lines with width
    By nasko in forum AutoCAD Drawing Management & Output
    Last Post: 16th May 2005, 06:20 pm
